Charting issues in 10
2828
01-16-2011 07:46 PM
JollyJacob
Hi All,
Any idea why the charting funtionality that used to work in ArcGIS 9.3.1 does not in 10.
Thanks in advance.
Regards
JollyJacob
To be more specific, after we moved to ArcGIS API 2.1 for SL.
DominiqueBroux
Esri Frequent Contributor
Due to changes in the charting toolkit, the sample is no more working when updating to SL4 and the new toolkit version.
I attached a new version of the sample working with SL4, ArcGIS SL2.1 and the latest toolkit.
Hope this help.
JollyJacob
Thanks Dominique,
the sample worked like a charm 🙂
However, thematic mapping is still not working with class breaks. Has the ClassBreakInfo or any thing else changed?
Thanks
Jolly
DominiqueBroux
You are welcome:)
Could you give more info about the class break issue?  (as the sample is not using ClassBreakInfo, I guess it's not an issue with the sample).
JollyJacob
Thematic mapping also working now Dominique, it was our mistake, some layer id mis-match.
However, if ESRI is interested in feedback, I would like to suggest that when free samples are given and then when code changes due to upgrades / other reasons, it would be good if ESRI posted updated sample codes, otherwise like us, we could be stranded in a situation where a functionality worked in an earlier version but now does not in a newer version.
Thanks for all your help.
