change the order of visibility of layer in the card silverlight
2917
11-28-2014 02:44 AM
sakinachafaqi
hello,
I want to create a list of visible layers in the map and change the order of visibility of these in the card silverlight. how to please.
thank you
JenniferNery
I think these SDK sample might help: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers (uses LegendControl in the Toolkit to update layer visibility).
You can get an enumerable of visible layers using Linq query
var visibleLayers = from l in MyMap.Layers
                              where l.Visible
                              select l;
If you need to re-order the layers, you can use Insert
MyMap.Layers.Insert(index, layer);
