Change map contrast/brightness
3853
08-27-2010 03:11 AM
AdolfoMarinucci
Hi all,
I have a project using latest version of ArcGIS SL client API that connects to an ArcGIS Server .net 10. I'm using ArcGISImageServiceLayer and ArcGISDynamicMapServiceLayer classes to shows some map layers.
Is there a way to allow users change at runtime contrast/brightness of resulting images? They need to identify some objects on these maps and this functuonality would be very useful.
Adolfo Marinucci
AliMirzabeigi
Hi Adolfo,
You can use the following code snippet to change the opacity of an image service layer based upon the value of a Slider control:
<esri:Map x:Name="MyMap" Extent="-13486609,5713307,-13263258,5823117">
            <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" />
            <esri:ArcGISImageServiceLayer Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Portland/CascadeLandsat/ImageServer"
                                          ImageFormat="PNG8" NoData="0"/>
        </esri:Map>
<Slider x:Name="MySlider" Width="200" HorizontalAlignment="Right" VerticalAlignment="Top"
            Minimum="0" Maximum="1" Value="1" Margin="0,10,10,0" />
And in the code-behind:
        public MainPage()
            InitializeComponent();
            MyMap.Layers.LayersInitialized += new LayerCollection.LayersInitializedHandler(Layers_LayersInitialized);
        void Layers_LayersInitialized(object sender, EventArgs args)
            MySlider.ValueChanged += MySlider_ValueChanged;
        private void MySlider_ValueChanged(object sender, RoutedPropertyChangedEventArgs<double> e)
            (MyMap.Layers[1] as ArcGISImageServiceLayer).Opacity = MySlider.Value;
AdolfoMarinucci
Thanks for your answer, but what I'm looking for is how to change the contrast/brightness  of the image downloaded not the opacity of the layer. We're working with aereal photos and improving their contrast/brighteness could help our users to identity objects present on the map.
Adolfo
dotMorten_esri
Esri Notable Contributor
There's an effect property on the layer that you can use for this. There are effects out there that allows you to control contrast and/or brightness.
You can for instance use this effects library: http://wpffx.codeplex.com/
Note that these effects often comes with a big performance penalty, so use them wisely.
