Can you Mix ESRI tiled services with Bing tiled services in the same map?
862
11-17-2011 11:36 AM
BrentStevener
We would like to display a mix of ESRI or Bing tiled imagery layers switched out dynamically. However, these are in different projections, so whichever one you load first is the only one that will display properly in the map. Is there a way around this? I have seen a Flex app utilize both in the same map app, so is this possible with Silverlight?
JenniferNery
BrentStevener
Thanks. Haven't had the ability to actually test yet, but seems like it might be possible through that.
