Can't set initial map centerPoint and resolution
3450
06-30-2015 07:01 AM
AnatoliiTerentiev
Dear Gurus!
Unexpected problem.
For some operations I decide to show new tab  with copy of the Map element from the current tab (in the tabControl).
            <esri:Map x:Name="MyMap"  Background="White" WrapAround="true"
                  Extent="3200000,8500000,4250000,10130000">
                <esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik" />
                <esri:ArcGISDynamicMapServiceLayer ID="Карта РК"
                            Url="http://myServer:6080/ArcGIS/rest/services/karelia/MapServer" />
                <esri:GraphicsLayer ID="MyGraphicsLayer" MouseLeftButtonDown="GraphicsLayer_MouseLeftButtonDown" />
        </esri:Map>
And want to set centerPoint and resolution from the first tab. In the next event
        <i:Interaction.Triggers>
            <i:EventTrigger EventName="Loaded">
                <i:InvokeCommandAction Command="{Binding SetMapRefCommand, Mode=OneWay}"
                                CommandParameter="{Binding ElementName=MyMap,Mode=OneWay}" />
            </i:EventTrigger>
        </i:Interaction.Triggers>
as follows in the ViewModel for this control
public void SetMapRef(object item)
     myMap = (Map)item;
     MapModule.ViewModels.MapViewModel.centerAndZoom(myMap, currentCentrPointFromFirst, MapResolutionFromFirst);
Where centerAndZoom procedure is
       public static void centerAndZoom(ESRI.ArcGIS.Client.Map map, ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint, double resolution)
            double ratio = 1.0;
            if (map.Resolution != 0.0)
                ratio = resolution / map.Resolution;
           if (ratio == 1.0)
                map.PanTo(mapPoint);
            else
                ESRI.ArcGIS.Client.Geometry.MapPoint mapCenter = map.Extent.GetCenter();
                double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio);
                double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio);
                map.ZoomToResolution(resolution, new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y));
But it does not work. When I do it from the click button Event - all works fine. I can't understand - what is the reason...
How to fix?
AnatoliiTerentiev
I want to create several views with the same Map element for different task. I am using Prism and want to be able to load views in the different regions with the same parameteres of the map. Can I do it and how if it is possible?
