Can't load the BING Map
1110
06-29-2012 06:16 AM
NigelAlford
I've been manipulating and learning dojo separately and now I'm integrating ArcGIS now. the map won't load I'm sure its something small but if someone has a second to point the flaw that would be great.
<!DOCTYPE HTML>
<html lang="en">
    <head>
        <meta charset="utf-8">
        <title>Demo: Javascript Map</title>
  <link rel="stylesheet" href="Styles/FloatingPane.css">
  <link rel="stylesheet" href="dojox/layout/resources/ResizeHandle.css" type="text/css">
        <link rel="stylesheet" href="Styles/style.css" media="screen">
        <link rel="stylesheet" href="http://ajax.googleapis.com/ajax/libs/dojo/1.7.1/dijit/themes/claro/claro.css" media="screen">
        <!-- load dojo and provide config via data attribute -->
        <script src="http://ajax.googleapis.com/ajax/libs/dojo/1.7.1/dojo/dojo.js"
                data-dojo-config="async:true, parseOnLoad:true">
        </script>
  <!--ESRI Injection-->
  <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.7" type="text/javascript"></script>
  <script type="text/javascript">djConfig = { parseOnLoad:true }</script>
  <link href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.7/js/dojo/dijit/themes/claro/claro.css" rel="stylesheet" type="text/css" >
  <!--End-->
  <script>
   require([
   "dijit/layout/BorderContainer", "dijit/layout/ContentPane","dijit/layout/AccordionContainer",
   "dojo/parser", "dojo/domReady!",
   "dojox/layout/FloatingPane"
  </script>
  <script type="text/javascript" charset="utf-8">
    dojo.require("esri.map");
    dojo.require("esri.virtualearth.VETiledLayer");
    function init ()
    map = new esri.Map("map");
    //Creates the Virtual Earth layer to add to the map
    veTileLayer = new esri.virtualearth.VETiledLayer({
          bingMapsKey: 'AimF6LphvVcbtQZOyiopeyQT8n-QOTukhwoRZwnzKL1MM0_B1Dfc7ppeKmyPByKp',
          mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
    map.addLayer(veTileLayer);
    dojo.addOnLoad(init);
  </script>
  <!--End-->
    </head>
    <body class="claro">
  <div id="appLayout" class="demoLayout" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design: 'headline'">
   <div class="centerPanel" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region: 'center', splitter: true"">
    <div id="map">
    <div data-dojo-type="dojox.layout.FloatingPane" id="dFloatingPane"
       title="Zoom-Bar" data-dojo-props="resizable:false, dockable:true"
       style="position:absolute;top:5;left:1;width:100px;height:300px;visibility:visible;">
    This is the content of the pane!
    </div>
    </div>
   </div>
   <div class="edgePanel" style="max-height: px, min-height: 50px;" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region: 'top', splitter: true">Header content (top)</div>
   <div data-dojo-type="dijit.layout.AccordionContainer" style="width: 25%" data-dojo-props="region: 'left', splitter: true"">
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'">
     <ul>
      <li> sample title </li>
     </ul>
    </div>
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Your Bookmarks', selected: true">
    Hi how are you?
    </div>
   </div>
  </div>
 </body>
</html>
JoeHershman
I would post in the javascript forum http://forums.arcgis.com/forums/15-ArcGIS-API-for-JavaScript
G
ood Luck
-Joe
NigelAlford
Wow I completely overlooked the forum title.
Post has been moved
