Question on editing attributes with Editor Widget
881
06-29-2012 08:20 AM
DanielSchatt
I'm using the Editor Widget to allow users to add points and then, after adding a point, choose a value for a field from a coded domain.  Ideally I'd like the users to need to choose the value manually (with an empty box displayed initially) but with empty values invalid.
So is it possible to have an empty input box be displayed initially for the field (on the attributes input window that pops up after clicking on the map to add a point) but not allow the user to apply the edit until a value from the coded domain is chosen?
The dilemma here seems to be that if a default empty value is displayed, than that empty value has to be valid.  But I only want values from the coded domain to be valid.  Thanks!
Dan
