Buffer Distance
4432
17
01-25-2011 09:22 AM
JayKappy
I have a buffer working off of a Query.
A query runs finding a Parcel
That selected feature then is used to run a buffer that selects another set of Feature within that buffer
It then returns them to a listbox
NOTE: everything works great...Just trying to figure out how if I can retrieve the distance each feature is to the buffer centerpoint.
How do I return the Buffer distance for each feature and put the distance in the listbox.
Is there something that I can do in the xaml below, or do I have to get the value in the vb code first?
Once that is gotten can I sort the values in the listbox Ascending via this buffer distance?
<TextBlock Foreground="White" Margin="0,4,0,0" VerticalAlignment="Center" Text="{Binding BUFFER_DISTANCE}" SORT="ASCENDING"  />
Is this even possible with the Buffer? I assume that its measuring the distance in order to determine if its inside the Buffer specified distance.....
Thanks
<ListBox.ItemTemplate>
     <DataTemplate>
           <StackPanel Orientation="Horizontal" VerticalAlignment="Center" >
                    <!-- QUERY -->
                    <StackPanel Margin="1">
                            <TextBlock Foreground="White" Margin="0,4,0,0" VerticalAlignment="Center" Text="{Binding Attributes[TYPE]}"/>
                     </StackPanel>
                     <StackPanel Margin="5,0,0,0" Orientation="Vertical">
                             <TextBlock Foreground="White" Text="{Binding Attributes[CITY_NAME], StringFormat='City Name: \{0\}'}" >
                                      <TextBlock.Effect>
                                              <DropShadowEffect/>
                                      </TextBlock.Effect>
                             </TextBlock>
                             <TextBlock Foreground="White" Text="{Binding Attributes[POP1990], StringFormat='Population: \{0\}'}"  >
                                      <TextBlock.Effect>
                                              <DropShadowEffect/>
                                      </TextBlock.Effect>
                             </TextBlock>
                        </StackPanel>
                    </StackPanel>
              </DataTemplate>
       </ListBox.ItemTemplate>
</ListBox>
JenniferNery
This Text="{Binding BUFFER_DISTANCE}"  will work if you add graphic Attribute with Key 'BUFFER_DISTANCE.' Yes, this need to be added in code-behind.
You can iterate through the graphics in your GraphicsLayer and calculate the Eucledian distance between buffer point and graphic.Geometry.Extent.GetCenter() and store into the graphic Attribute.
For Each g As var In MyGraphicsLayer.Graphics
 Dim c As MapPoint = g.Geometry.Extent.GetCenter()
 g.Attribute("BUFFER_DISTANCE") = GetDistance(bufferPoint, c)
There is no Sort property on TextBox. If you wish to sort the ListBox contents against this Attribute, you can sort using Linq before setting ItemSource or use CollectionViewSource.
JayKappy
What you are saying makes sense.....I think my application is a bit different...
The user clicks a button that does a search on a value from a textblock.
The Parcel is located adn zoomed to
A buffer is created from that found parcel geometry
The buffer then selects the points within that buffer and returns the results to a listbox.
I am not seeing the location to place the code to calculate the Buffer Distance
            ' DRAW THE BUFFER AND USE THE PARCEL TO CREATE THE INITIAL POINT OF THE BUFFER
            _geometryService = New GeometryService("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer")
            AddHandler _geometryService.BufferCompleted, AddressOf GeometryService_BufferCompleted2
            AddHandler _geometryService.Failed, AddressOf GeometryService_Failed2
            _queryTask = New QueryTask("http://gis.logis.org/arcgis/rest/services/MG_Test_WGS84/MapServer/1")
            AddHandler _queryTask.ExecuteCompleted, AddressOf QueryTask_ExecuteCompletedBuffer2
            AddHandler _queryTask.Failed, AddressOf QueryTask_Failed2
It seems I would put it here:
For Each selectedGraphic As Graphic In args.FeatureSet.Features
selectedGraphic.Symbol = TryCast(LayoutRoot.Resources("DefaultMarkerSymbol"), ESRI.ArcGIS.Client.Symbols.Symbol)
_resultsGraphicsLayer.Graphics.Add(selectedGraphic)
Next selectedGraphic
But then I get confused because I am binding the imagelistbuffer (listbox) here
imageListBuffer.ItemsSource = args.FeatureSet.Features
    Private Sub GeometryService_BufferCompleted2(ByVal sender As Object, ByVal args As GraphicsEventArgs)
        Dim bufferGraphic As New Graphic()
        bufferGraphic.Geometry = args.Results(0).Geometry
        bufferGraphic.Symbol = TryCast(LayoutRoot.Resources("BufferSymbol"), ESRI.ArcGIS.Client.Symbols.Symbol)
        bufferGraphic.SetZIndex(1)
        _pointAndBufferGraphicsLayer.Graphics.Add(bufferGraphic)
        Dim query As New ESRI.ArcGIS.Client.Tasks.Query()
        query.ReturnGeometry = True
        query.OutSpatialReference = MyMap.SpatialReference
        query.Geometry = bufferGraphic.Geometry
        query.OutFields.Add("*")
        _queryTask.ExecuteAsync(query)
    End Sub
    Private Sub QueryTask_ExecuteCompletedBuffer2(ByVal sender As Object, ByVal args As QueryEventArgs)
         ' Bind the results to the listbox
        Dim featureSet As FeatureSet = args.FeatureSet
        If args.FeatureSet.Features.Count < 1 Then
            MessageBox.Show("No features found")
            Return
        End If
    End Sub
JayKappy
I tried this but nothing going on the: GetDistance(bufferPoint,c)
        Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayerBufferResults"), GraphicsLayer)
        For Each g As Graphic In graphicsLayer.Graphics
            g.Attributes("BUFFER_DISTANCE") = GetDistance(bufferPoint, c)
            Return
        End If
    End Sub
dotMorten_esri
Esri Notable Contributor
Isn't it the args.FeatureSet.Features that you want to add the attribute to, and not the graphics layer? (since this is what you bind to the listbox).
JayKappy
I tried this as well just didnt put it in the forum...
I am having a problem I think because the params on the Sub are args As QueryEvent and geometry is not a member of ESRI Tasks.QueryEventArgs
So I cant see how to get teh geometry from the center of each feature
Do I need to do this in a different method or change the Sub Params?
This the only sub tht I can think of placing this data as this is where i am binding the results to the listbox..
            Return
        End If
            Dim c As MapPoint = args.Geometry.Extent.GetCenter()
            args.Attributes("BUFFER_DISTANCE") = GetDistance(bufferPoint, c)
Then tried this: But the GetDistance errors out saying that GetDistance and bufferPoint are not declared...
            Dim c As MapPoint = selectedGraphic.Geometry.Extent.GetCenter()
            selectedGraphic.Attributes("BUFFER_DISTANCE") = GetDistance(bufferPoint, c)
.I cannot see the solution here..anyone? THanks
uggggggggggggggggggggg
JayKappy
Am I wasting my time by doing this here in the ... if I am even tryign this in the righ location....or even trying to do it correctly
It seems that GetDistance is not an option
JayKappy
I tried this as well....adding
ESRI.ArcGIS.Client.Geometry.MapPoint
instead of just MapPoint...keeps telling me that GetDistance and bufferPoint not defined.
            Return
        End If
            Dim c As ESRI.ArcGIS.Client.Geometry.MapPoint = selectedGraphic.Geometry.Extent.GetCenter()
    End Sub
Is GetDistance supposed to be a function that I am passing 'c' to in order find the distance?
Seems the way I have things set up it cant find the Buffer Point???? only the c (the parcel center point) is defined.
The center point of the buffer was defined in an ealier sub routine...
JayKappy
I take it I hit my question limit....wish I had another location to ask questions....I know that I am close here...thanks anyway...although still open for help
JayKappy
Io think that I can get the Buffer Graphics center like this: See RED below, BUT its not in the correct Sub Routine...
I need to get that center location to the Private Sub QueryTask_ExecuteCompletedBuffer2 in order to calculate the Distance from the Buffer center to the features found inside the buffer.
        Dim bp As ESRI.ArcGIS.Client.Geometry.MapPoint = bufferGraphic.Geometry.Extent.GetCenter()
    End Sub
            Return
        End If
            selectedGraphic.Attributes("BUFFER_DISTANCE") = GetDistance(bp, c)
    End Sub
