Bind graphics of GraphicLayer.[Bind GraphicCollection]
3485
08-06-2010 06:14 AM
StefhanCampos
hi,
I am using MVVM approuch and i need bind graphics of GraphicLayer i try:
<esri:GraphicsLayer ID="test" Graphics="{Binding graphics}" />
private GraphicCollection graphics;
        public GraphicCollection Graphics
            get {
                return graphics;
            set {
                graphics = value;
                OnPropertyChanged("graphics");
the application hangs, not display nothing...anyone know how i can solve this issue?
JenniferNery
You can define your GraphicCollection in Xaml under UserControl.Resources as such:
  <esri:GraphicCollection x:Key="MyGraphics" />
and then create the binding to Graphics this way:
  <esri:GraphicsLayer ID="MyGraphicsLayer"
                                Graphics="{Binding Source={StaticResource MyGraphics}}">
Any changes to your GraphicCollection should affect the Graphics in your GraphicsLayer.
Jennifer
BjørnarSundsbø
Hi
How do I get MyGraphics to contain the data from my ViewModels Graphics collection without monitoring changes to my viewmodel and adding them to the resource?
JenniferNery
If you want to define the Binding in XAML, I don't see another way to do so without defining an instance of your ViewModel under Resource.
If your ViewModel object looked like this
   public class MyViewModelObject : INotifyPropertyChanged
        public MyViewModelObject()
            Graphics = new GraphicCollection();
            get { return graphics; }
            set
                if (graphics != value)
                    graphics = value;
                    OnPropertyChanged("Graphics");
        public event PropertyChangedEventHandler PropertyChanged;
        public void OnPropertyChanged(string property)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(property));
You might be expecting that when you set your UserControl's DataContext to an instance of your ViewModel in code-behind like this:
            MyViewModelObject obj = new MyViewModelObject();
            this.DataContext = obj;
the following XAML-code would just work:
            <esri:GraphicsLayer ID="MyGraphicsLayer" Graphics="{Binding Graphics}">
Unfortunately, this is not the case. While your Map can inherit the DataContext of your UserControl, GraphicsLayer will not. GraphicsLayer, unlike Map or any other UIElement, does not have a DataContext and will therefore fail to resolve this type of Binding.
If you wish to define the Binding in code-behind, these two are equivalent:
XAML:
        <Grid.Resources>
            <local:MyViewModelObject x:Key="obj"/>
        </Grid.Resources>
<!-- more code here -->
  <esri:GraphicsLayer ID="MyGraphicsLayer" Graphics="{Binding Source={StaticResource obj}, Path=Graphics, Mode=TwoWay}" >
Code-behind:
            GraphicsLayer layer = this.MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            System.Windows.Data.Binding binding = new System.Windows.Data.Binding("Graphics");
            binding.Source = obj;
            binding.Mode = System.Windows.Data.BindingMode.TwoWay;
            System.Windows.Data.BindingOperations.SetBinding(layer, GraphicsLayer.GraphicsProperty, binding);
Either way will let you modify the elements in your Map's GraphicsLayer.
            obj.Graphics.Add(new Graphic() { Geometry = new MapPoint(17, 15) });
