MeasureAction Text Symbol
947
09-14-2010 12:59 PM
WilliamKimrey
Hello all,
Just wondering if it's possible to change the RotatingTextSymbols used by the Measure Action to display distances and areas.
More specifically, I want the text symbol for distances to always be on the line instead of being below the line once the angle is past a certain point.  I also would like the Total Value (wheter it's distance or area) to not be shifted down and right from the final vertex.  I'd love if I was able to put this information in the Center of the Graphic.
Will
DavidFlack
Will, did you get a resolution on this?  I have a very similar question.
JenniferNery
I'm afraid the symbols used in MeasureAction is not customizable.
However, others have found a way to copy the graphics created by MeasureAction onto their map. You can refer to this forum: http://forums.arcgis.com/threads/13902-about-after-using-measure-behavior-the-graph-can-t-stay-in-th... Maybe you can use the same approach and replace the TextSymbol with your own by checking the type of Symbol.
