Bind a TextBlock to the Map's Resolution
1308
02-22-2011 08:49 AM
TedChapin
Does anyone know why this:
<TextBlock Text="{Binding Resolution, ElementName=MapMain, Mode=OneWay}" ></TextBlock>
produces "NaN" instead of the map's resolution?  I tried the same thing with the map's Extent.Width property and it works fine.
JenniferNery
I think you have it correctly if your map control is named "MapMain". However, v2.1 and earlier do not support Binding for "Resolution", this is new to v2.2
The following code will only work for v2.2 and up:
<TextBlock Text="{Binding ElementName=MyMap, Path=Resolution}" VerticalAlignment="Top" HorizontalAlignment="Center"/>
The following code will work for v2.1 and earlier:
<TextBlock x:Name="MyResolution" Text="0" VerticalAlignment="Top" HorizontalAlignment="Center"/>
private void MyMap_ExtentChanged(object sender, ExtentEventArgs e)
 double res = Convert.ToDouble(MyResolution.Text);
 if (res != (sender as Map).Resolution)
  res = (sender as Map).Resolution;
  MyResolution.Text = res.ToString();
DavidLamb
Where is v2.2 available?
David
JenniferNery
When it becomes available, there should be a link from here: http://help.arcgis.com/en/webapi/silverlight/index.html
to beta community site: https://betacommunity.esri.com/home.html
