How to change the cursor when doing measure action?
1294
03-01-2011 06:37 PM
DanDong
Hi all,
I want to change the cursor from hand shape to arrow shape when doing measure action. I have changed the measure action from XAML to code-behind.
private void Measure_Click(object sender, System.Windows.RoutedEventArgs e)
MyMap.Cursor = Cursors.Arrow;   //change the cursor to arrow shape
MyMeasureAction m = new MyMeasureAction();  //initialize a MyMeasureAction class
m.MeasureMode = ESRI.ArcGIS.Client.Actions.MeasureAction.Mode.Polygon;  //MeasureMode is polygon
m.DisplayTotals = false;    //do not display total distance
m.FillSymbol = LayoutRoot.Resources["DrawFillSymbol"] as FillSymbol;
m.DistanceUnit = ESRI.ArcGIS.Client.Actions.DistanceUnit.Feet;
m.MapUnits = ESRI.ArcGIS.Client.Actions.DistanceUnit.Feet;  //the unit of the map is Feet
m.Attach(MyMap);    //bind this action to MyMap
m.Execute();    //execute this action
But the weird thing is when I hit the button, the cursor cannot be changed to arrow shape. If I put this line under other button click events. It works.
I guess this might due to the measure action itself? In the sample, it use hand cursor to perform measure action. Is there any method to change the cursor shape? Thank you! 🙂
JenniferNery
This is by design, map.Cursor is changed to Cursors.Hand while MeasureAction is active and then changed back to previous cursor when disabled.
DanDong
Does that mean I cannot change the cursor shape when measure action is doing its work?
JenniferNery
MeasureAction already overrides the map cursor and cannot be changed, sorry.
DanDong
Ok �?�? at least I know that we cannot change it. Thank you Jennifer 🙂
