ArcGIS API for SIlverlight 3.1 SIlverlight 5:  identify task
2210
04-20-2013 08:41 AM
EssyJames
I have the following using statements:
using ESRI.ArcGIS.Client;
using ESRI.ArcGIS.Client.Geometry;
using ESRI.ArcGIS.Client.Printing;
using ESRI.ArcGIS.Client.Tasks;
using ESRI.ArcGIS.Client.Toolkit;
using ESRI.ArcGIS.Client.Toolkit.Primitives;
but I get an error in this line:
private List<DataItem> dataItems = null;
The type or namespace name 'DataItem' could not be found (are you missing a using directive or an assembly reference?
DaveTimmins
The DataItem class is just used to define your object to bind your data to the view. If you  look at the code for the identify sample in the interactive SDK http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#Identify the DataItem is defined at the bottom of the file
public class DataItem
            public string Title { get; set; }
            public IDictionary<string, object> Data { get; set; }
Cheers,
