Loaded Service urls dynamically?
884
04-19-2013 07:08 AM
matthewbennion
I'm guessing this isn't possible for all layers but, I have a live and dev instance of a system and the services in each to point different urls.
    Private Sub Map1_Loaded(ByVal sender As Object, ByVal e As RoutedEventArgs)
        Dim strAddress As String = Application.Current.Host.Source.ToString
        Dim strServiceAddressOrganisations As Strin
        'refresh of cluster boundaries dynamic map service layer endpoint
        dynamicMapServiceLayerClusterBoundaries = Map1.Layers("Cluster Boundaries")
        dynamicMapServiceLayerClusterBoundaries.DisableClientCaching = True
        dynamicMapServiceLayerClusterBoundaries.Url = servicesAddress & "/Clusters/MapServer/"
        'refresh of organisations feature layer endpoint
        featureLayerOrganisations = Map1.Layers("Organisations")
        featureLayerOrganisations.DisableClientCaching = True
        featureLayerOrganisations.Url = strServiceAddressOrganisations
        dt.Start()
    End Sub
The code doesn't work and complains no URLS have been set, I'm guessing this is because in the XAML no urls are set?
DaveTimmins
The code below looks like it has some errors, the third line of code is missing a g on the end and the strServiceAddressOrganisations variable is never set. In terms of setting the url's dynamically you can do it, there are a number of options. You can set values in your web.config and pass them through to the Silverlight plugin, or have them in a database and provide access via a service or the like or you can load the xaml dynamically which contains the layer markup. A couple of blogs that discuss some of these techniques are
http://davetimmins.wordpress.com/2011/07/22/dynamically-loading-layers-at-runtime-with-silverlight/
http://www.gal-systems.com/2011/08/passing-parameters-to-silverlight.html
Cheers,
