Add Text to MapProgressBar
2619
01-25-2012 08:11 AM
MargoBlosser
I need a mapprogressbar that has the graphical status bar and text in addition to the percent complete text.
The control text would be something like �??Fetching Data�?� and the percent complete text on top of the graphical status bar.
I have looked at the example at  http://help.arcgis.com/en/webapi/silverlight/apiref/api_start.htm and in the example in the Samples directory, but can�??t see how to do this.
Can someone point me in the right direction?
Best Regards,
Margo
Best Regards,
Margo
JenniferNery
The following SDK sample use MapProgressBar: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MapProgressBar. Should you need to customize the control to add TextBlock, you can follow this blog post http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/05/28/Localizing-ArcGIS-Controls.aspx. Source code can be found here: http://esrisilverlight.codeplex.com/, if you find that behavior of ProgressBar also need to change.
