Map saved to a bitmap file
1118
02-06-2011 10:49 AM
MarkBaird
I'm trying to get a Silverlight application to save the currrent contents of the map control to a png file or eventually a PDF.  This means that I've got to get the contents of the map into a bitmap.
I've had all sorts of problems due to my map being made of contents from different domains.  I've got the following layers:
- bing maps
- an ArcGIS Server dynamic map service
- a graphics layer
Now I've partially solved the issue with data from different domains by using the proxyurl as in the following link.
http://help.arcgis.com/en/webapi/silverlight/help/index.html#/Secure_services/016600000022000000/
Nowever this doesn't solve the issue with the bing maps layer...  is there a solution to this?
//this is for getting the bing graphics:
WriteableBitmap layer0 = new WriteableBitmap(Map.Layers[0].ToBitmap());
results in:
Pixels = 'layer0.Pixels' threw an exception of type 'System.Security.SecurityException'
It's because the data is from a different domain...
MarkBaird
Just wondering if anyone had any experience of getting the Bing imeragery into a bitmap?
It's a nasty problem that prevents the app from exporting pdf, png etc images of the map for reporting purposes.
Any help appreciated
Ramonvan_Bruggen
I have the same question! I'm trying to capture the current map layout including all graphics to a image, but I get the Pixel  'System.Security.SecurityException'
