10.1 sample of QueryDataSource Class is not working
2487
12-11-2012 09:42 AM
TomWang
I have tried VB sample code on esri site. it is not working.
Please advise!
<Grid x:Name="LayoutRoot">
  <!-- Add a Map Control. Zoom to the East-Central United States. -->
  <esri:Map Background="White" HorizontalAlignment="Left" Margin="0,204,0,0" Name="Map1"
          VerticalAlignment="Top" Height="350" Width="500" Extent="-10349730,3871622,-8642421,5066738">
    <!--Add an ArcGISTiledMapServiceLayer as a backdrop. It has uses SpatialReference WKID=102100 (3857). -->
    <esri:ArcGISTiledMapServiceLayer ID="myArcGISTiledMapServiceLayer"
      Url="http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer" />
  </esri:Map>
  <!-- Button to add a Dynamic Layer (using QueryDataSource) via code-behind. -->
  <Button Content="Add a QueryDataSource based Dynamic Layer" Height="23"
          HorizontalAlignment="Left" Margin="0,175,0,0" Name="Button1" VerticalAlignment="Top" Width="500"
          Click="Button1_Click"/>
  <!-- Provide the instructions on how to use the sample code. -->
  <TextBlock Height="145" HorizontalAlignment="Left" Name="TextBlock1" VerticalAlignment="Top" Width="788"
    TextWrapping="Wrap" Text="Click the button to add a Dynamic Layer (the state of Kentucky) via code-behind using
    a QueryDataSource. The Dynamic Layers used in this example code are based upon using a LayerDataSource that
    is undiscoverable via the public ArcGIS Server Directory REST pages. The 'WorkspaceID' and 'DataSourceName'
    for each Dynamic Layer must be provided to the developer by Manager/Adminstrator of the
    ArcGISDynamicMapServiceLayer. Examples of the 'WorkspaceID' and 'DataSourceName' are provided as comments in
    code-behind for a public ArcGIS Server that has Dynamic Layers enabled via the LayerDataSource object."/>
</Grid>
Private Sub Button1_Click(sender As System.Object, e As System.Windows.RoutedEventArgs)
  ' Add a Layer on-the-fly based on an ArcGISDynamicMapServiceLayer that has Dynamic Layer capabalities enabled.
  ' The Layer being added DOES NOT come from an existing sub-layer in a LayerMapSource. Rather the Dynamic Layer
  ' is being generated uses the 'Workspace Type' of 'Database' via the LayerDataSource object. Review the
  ' ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer Class documentation in the API reference for a full discussion.
  ' In order to create this Dynamic Layer, information was shared between the Manager/Admininstrator of the
  ' ArcGISDynamicMapServiceLayer ArcGIS Server service and the application developer.
  ' The Url for the ArcGISDynamicMapServiceLayer is: "http://servicesbeta2.esri.com/arcgis/rest/services/USA/MapServer".
  ' The WorkspaceID used in the LayerDataSource for the Dynamic Layer is: "MyDatabaseWorkspaceIDSSR2"
  ' There are several DataSourceName types associated with the WorkspaceID that could be used to create the Rendering
  ' of a Dynamic Layer. Think of the DataSourceName as the string name of the layer that will be drawn dynamically.
  ' A listing of the available DataSourceNames (and their geometry type) are:
  ' "Demo.DBO.USAreaCodes" <== Polygons
  ' "Demo.DBO.USCities" <== Points
  ' "Demo.DBO.USCounties" <== Polygons
  ' "Demo.DBO.USHighways" <== Polylines
  ' "Demo.DBO.USLakes" <== Polygons
  ' "Demo.DBO.USPlaces" <== Points
  ' "Demo.DBO.USRailroads" <== Polylines
  ' "Demo.DBO.USRivers" <== Polylines
  ' "Demo.DBO.USStates" <== Polygons
  ' Create a QueryDataSource object and set all of it's Properties to valid values.
  Dim myQueryDataSource As New ESRI.ArcGIS.Client.QueryDataSource
  myQueryDataSource.GeometryType = ESRI.ArcGIS.Client.Tasks.GeometryType.Polygon
  Dim myOIDFields As String() = {"OBJECTID"}
  myQueryDataSource.OIDFields = myOIDFields
  myQueryDataSource.Query = "SELECT * FROM Demo.DBO.USStates where STATE_NAME = 'Kentucky'"
  Dim mySpatialReference As New ESRI.ArcGIS.Client.Geometry.SpatialReference(4326)
  myQueryDataSource.SpatialReference = mySpatialReference
  myQueryDataSource.WorkspaceID = "MyDatabaseWorkspaceIDSSR2"
  ' Create a new LayerDataSource and set its DataSource Property to the QueryDataSource.
  Dim myLayerDataSource As New ESRI.ArcGIS.Client.LayerDataSource
  myLayerDataSource.DataSource = myQueryDataSource
  ' Create a new DynamicLayerInfo object and set its ID and Source Properties.
  Dim myDynamicLayerInfo As New ESRI.ArcGIS.Client.DynamicLayerInfo
  myDynamicLayerInfo.ID = 102 ' Must be the same as the LayerDrawingOptions.LayerID
  myDynamicLayerInfo.Source = myLayerDataSource
  ' Create a new DynamicLayerInfoCollection and add the DynamicLayerInfo object into it.
  Dim myDynamicLayerInfoCollection As New ESRI.ArcGIS.Client.DynamicLayerInfoCollection
  myDynamicLayerInfoCollection.Add(myDynamicLayerInfo)
  ' Create a SimpleFillSymbol (Green Fill, with Black Border, and BorderThickness of 2).
  Dim mySimpleFillSymbol As New ESRI.ArcGIS.Client.Symbols.SimpleFillSymbol
  mySimpleFillSymbol.Fill = New System.Windows.Media.SolidColorBrush(Colors.Green)
  mySimpleFillSymbol.BorderThickness = 2
  mySimpleFillSymbol.BorderBrush = New System.Windows.Media.SolidColorBrush(Colors.Black)
  ' Create a new SimpleRenderer based upon the SimpleFillSymbol.
  Dim mySimpleRenderer As New ESRI.ArcGIS.Client.SimpleRenderer
  mySimpleRenderer.Symbol = mySimpleFillSymbol
  ' Create a new LayerDrawingOptions object which is key to applying our custom Rendering of the Dynamic Layer.
  ' It is imperative that the LayerDrawingOptions.LayerID = DynamicLayerInfo.ID so that the Dynamic Layer draws
  ' using the new symbology.
  Dim myLayerDrawingOptions As New ESRI.ArcGIS.Client.LayerDrawingOptions
  myLayerDrawingOptions.LayerID = 102 ' Must be the same as the DynammicLayerInfo.ID
  myLayerDrawingOptions.Renderer = mySimpleRenderer
  ' Create a new LayerDrawinOptionsCollection and add the LayerDraingOptions object into it.
  Dim myLayerDrawingOptionsCollection As New ESRI.ArcGIS.Client.LayerDrawingOptionsCollection
  myLayerDrawingOptionsCollection.Add(myLayerDrawingOptions)
  ' Create a new Dynamic Layer that is based upon on a LayerDataSource of an ArcGISDynamicMapServiceLayer
  ' and apply it's custom rendering.
  Dim myArcGISDynamicMapServiceLayer As New ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer
  myArcGISDynamicMapServiceLayer.Url = "http://servicesbeta2.esri.com/arcgis/rest/services/USA/MapServer"
  myArcGISDynamicMapServiceLayer.DisableClientCaching = True
  myArcGISDynamicMapServiceLayer.DynamicLayerInfos = myDynamicLayerInfoCollection
  myArcGISDynamicMapServiceLayer.LayerDrawingOptions = myLayerDrawingOptionsCollection
  ' Add the Dynamic Layer to the Map Control. This causes the round trip server request to occur.
  Map1.Layers.Add(myArcGISDynamicMapServiceLayer)
End Sub
tomw
I would like to hear a response from Esri if the query datasource api works or not.
Thanks
