X/Y coordinates in pandas dataframe to map
15103
12
07-25-2017 07:20 AM
DavidRalston
Is there a way to add x/y coordinate columns in a pandas dataframe to a map using the arcgis python api in jupyter notebook?
IonutAlixandroae4
Hi David,
I also had this problem in another topic on this group. The solution was the way Rohid said, but with coordinates in DD format. I had the list of coordinates in DMS format and it wasn`t working for me.
See here: https://community.esri.com/thread/198787-display-array-of-multiple-coordinates-xy-in-the-map-object
Ionut
GregoryBrunner
rsingh-esristaff
How does this work it my data is in a different coordinate system (i.e. not WGS 1984)?
RohitSingh2
The layer/FeatureCollection to be added should have a correct spatial reference set in that case. I don't have the code offhand to do this though. Another way would be to use arcgis.geometry.project to project the coordinates to WGS1984.
