WebMap Created with Python API missing from Collector
1841
06-11-2020 07:20 AM
מנהל_תקשובמנהל_מערכת
 Hi I 've created WebMap  and sheared it to Group with Python API . all went well and I can view it and edit it in ArcGis Online but the map is missing from collector. only after I open the map in ArcGis Online and Save it from there I could see it in the collector.
I have exported the JSON files for before and after the change, and notice there are some differences.
Maybe the code for new WebMap is missing something.
this is the code I used to create the WebMap:
#create webmap in AGOL and add the Layers and save
Survey_Webmap = WebMap()
SurLyr=gisCon.content.get(known_item_id)
Survey_Webmap.add_layer (SurLyr)
webmap_item_properties = {'title':SurTitle+"_WM",'tags':['Surveys'],'snippet':'Survey of Israel'+surv_id}
#search for the created webmap item id
Survey_Webmap.save(item_properties=webmap_item_properties,folder= myFolder)
search_result_SurWebMap = gisCon.content.search(query=SurTitle+"_WM", outside_org=False)
first_item = search_result_SurWebMap[0]
known_WebMapitem_id = first_item.id
print(known_WebMapitem_id)
try:
    first_item.share(org=False,groups=SurveyGrp,everyone=False)
    print("Successfully shared item group")
except Exception as err:
    print("Something went wrong...")
    print(str(err))
 I'm attaching the Json Files and  2 images that shows the differences.
can anyone help me on this ?
I got it to work for me, though I think it some kind of bug since this parameter should be derive for the layers in the webmap, exactly as it work manually.
In any case this is my solution:
Add the keyword "typeKeywords" to "item_properties" and,  specify "'Collector', 'Data Editing'" that are missing when Arcgis Python API creates the webmap.
#create WebMap
#add oprational ediable layer
#create WebMap Item Prop
webmap_item_properties = {'title':SurTitle+"_WM",'tags':['Surveys'],'snippet':'Survey of Israel'+surv_id,'typeKeywords':['ArcGIS Online', 'Collector', 'Data Editing', 'Explorer Web Map', 'Map', 'Offline', 'Online Map', 'Web Map']}
#save the map
 hope it helps someone,
iris
