wanting to populate field using python script
1029
06-05-2024 11:57 AM
DevarsiMajumder
We have an emergency GRID that is comprised of  250  squares each with its labeling feature and naming ID.  we have some Assets that fall within each grid and we would like to generate or make a script that would recognize which grid square it is in and assign it an ID number automatically.  Is there something like this that anyone knows of that we can use or plug and play?  Thank you.
EarlMedina
There was a fairly similar question asked the other week. You can use the API to do a spatial join and then update the target field accordingly. See this example: Re: "Select By Location" and "Updat... - Esri Community
