ViewManager.create with overwrite=True option throws an error, does not complete
3526
11
06-10-2024 08:57 AM
Dirk_Vandervoort
According to the documentation: https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html#viewmanager, to create a hosted feature layer view in code with the overwrite option:
create(name, spatial_reference=None, extent=None, allow_schema_changes=True, updateable=True, capabilities='Query', view_layers=None, view_tables=None, *, description=None, tags=None, snippet=None, overwrite=None, set_item_id=None, preserve_layer_ids=False, visible_fields=None, query=None)¶
overwrite Optional Boolean. If true, the view is overwritten, False is the default.
In my code:
the_view = the_item.view_manager.create(name=the_view_name, view_layers=the_layers, overwrite=True)
Throws an error:
local variable 'logging' referenced before assignment
and does not complete.
The same issue is exposed with creating the view using this method:
flc = FeatureLayerCollection.fromitem(the_item)
the_view = flc.manager.create_view(name=the_view_name, view_layers=the_layers, overwrite=True)
Can someone lend me a hand?
TIA
EarlMedina
Ah, okay. So, right now are you doing this manually?
If all that's changing in the source data is the addition/removal of a few fields here and there, I think you can just:
  1. Update the View feature layer definition to match the current source fields
  2. Update the View definition if necessary
Hopefully, I've understood what you're needing to do.
Dirk_Vandervoort
We are adding and removing layers to the source Hosted Feature Layer. The itemID of the Hosted Feature Layer does not change. However, when you add/remove layers to a Hosted Feature Layer, the supporting Hosted Feature Layer Views get corrupted because the indexes of the layers in the Hosted Feature Layer have changed.
We cannot simply repair the source layers in the Hosted Feature Layer View to point to the correct layer in the Hosted Feature Layer, because the Views are created in code and are not supported/editable in the AGOL UI. That's why I was hoping "Overwrite=True" would work- we could simply recreate the View using the same code I used to construct the View in the first place. The View itemID would get preserved and apps that consume the View would be none-the-wiser.
so yeah, we're trying to modify the Views in code. Cheers.
