Upload against a Hosted Feature Service?
2262
01-24-2019 02:36 AM
SimonJackson
  • I have a polygon featureclass in a local file Geodatabase.
  • I want to Append-Upsert this against an existing Hosted Feature Service in AGO (same schema)
  • I know that you can upload the fGDB against the hosted feature service and then use this in an Append with appendUploadId
  • I might be missing it, but the the ArcGIS Python API seems to be missing this capability - to perform an upload against an existing hosted feature service?
I know there are other options:
  • Upload the fGDB to the portal as an item, and then use this in an append (prefer to avoid this approach)
  • Convert the layer to a featurecollection and pass this in directly with the edits param on append
    • Not entirely sure how to convert my featureclass to a featurecollection (?) in order to do this, happy to attempt this approach as then I can skip out on any uploading.
Thanks for any pointers.
simoxu
by MVP Alum
Hi Simon,
Is this what you are looking?
arcgis.features module — arcgis 1.5.2 documentation
Or you can use edit_features(adds=None, updates=None,....)
There is an example for it
updating_features_in_a_feature_layer | ArcGIS for Developers
Hope these information are useful for you
Cheers
SimonJackson
Hey again Simo
No its not so much the actual appending, its the uploading of a fGDB against the Hosted Feature Service itself (as opposed to an item in the portal) which I cant spot an easy way of doing without using the requests library and working directly with the REST endpoint.
Will see if I can share some code.  Here is a Javascript equivalent.
simoxu
by MVP Alum
Hello Simon,
It seems we have to do it in two steps:
Step 1: update the File Geodatabase item
Step 2: use the File Geodatabase item to update the Feature Service via append function which supports upsert.
I did a quick test here, and it seems works fine.
It would be good if we can update the feature service using zipped FGDB directly. and I don't know why the API doesn't. Hope someone from the development team can comment on this.
But we can workaround it by delete the zipped FGDB item after the update. I am just guessing, it really depends on your own workflow
Cheers
SimonJackson
You can actually bypass the above approach of uploading directly to the portal as an item (still a very valid approach for appending) and upload your fGDB directly against a hosted feature service.
Benefit is that this data is manually cleaned automatically by the back-end Server and no reliance on you having to delete.
Appending definitely supports using this via the appendUploadID parameter on the REST endpoint.
But with the Python API:
  • Cant spot anything that might help me upload to begin with
  • The append method does not have an equivalent appendUploadID, just a Portal Item ID - item_id
I am ok working around this by using the requests module, but might be worth including in a future release?
simoxu
by MVP Alum
I see.
There is a method called upload for the FeatureLayerCollection class.
but the append function for FeatureLayer does not have a upload_id parameter, and in the source code I can see the upload_id was intentionally set to None. So I assume the upload_id was deliberately disabled for the function.
