Update Hosted Table overwriting it with local CSV
17023
15
07-14-2021 01:28 PM
GPGeoespacialIDSM
I have a hosted table and I want to update it every day with new data (which includes old data). So what I need is to overwrite the entire hosted table exactly as I would clicking on AGOL item details interface "Update Data" > "Overwrite entire layer".
I tried:
gis = GIS("https://myorganization.maps.arcgis.com","user","pass")
# the hosted table item
table_ago = gis.content.get('xxxxxxxxxxxx')
#trying to update the item
table_ago.update({}, data=r'C:\\path\\table.csv')#it has the same name as the original csv from which the hosted table was published
[out] True # the output seems ok, but no updates on AGOL
# then try to republish
table_ago.publish(file_type='csv',overwrite=True)
[out] Traceback (most recent call last):
  File "<ipython-input-112-378e1e03b9c6>", line 1, in <module>
  File "C:\conda\envs\covid-amazonas\lib\site-packages\arcgis\gis\__init__.py", line 11977, in publish
    elif not buildInitialCache and ret[0]["type"].lower() == "image service":
KeyError: 'type'
Then I tried to do it using a Feature Collection:
# get it as a feature collection
table_ago_FC = FeatureLayerCollection.fromitem(table_ago)
# trying to update
table_ago_FC.manager.overwrite('C:\\path\\table.csv')
  File "<ipython-input-122-4098b20bab21>", line 1, in <module>
  File "C:\conda\envs\covid-amazonas\lib\site-packages\arcgis\features\managers.py", line 2036, in overwrite
    if bool(self._fs.replicas.get_list()):
AttributeError: 'FeatureLayerCollection' object has no attribute 'replicas'
What is wrong? How can I do it?
emedina
I'm sorry I spaced here, haha. The problem is probably that the body is in the wrong format and there are a few ways to fix that. I've got a moment to actually think out the code now. If you wanted to use a straight pandas DataFrame, you could create the required body like so:
# Generate array for applyEdits updates
updates = [{'attributes':{'OBJECTID':row['OBJECTID'],
'EXAMPLEFIELD1':row['EXAMPLEFIELD1'], 'EXAMPLEFIELD2':row['EXAMPLEFIELD12']}}
for index, row in df.iterrows()]
It looks like you can take a shortcut and do this more simply like so with GeoAccessor:
import pandas as pd
from arcgis import GIS
from arcgis.features import GeoAccessor, FeatureLayer
gis = GIS(your_org_url, username, password)
table_url = "whatever/your/url/is/0"
tbl = FeatureLayer(table_url, gis=gis) # works for tables
tbl.manager.truncate() # truncate table
casos_csv = r'C:\\path\\casos_am_MS.csv'
df = GeoAccessor.from_table(casos_csv )
adds = df.spatial.to_featureset()
tbl.edit_features(adds=adds)
You can certainly use append - I won't argue with the Development team on the appropriateness if you are adding a large number of records, but I have never had an issue myself. I think you would have to upload the csv in that scenario unless you converted it to one of the other formats.
MehdiPira1
@GPGeoespacialIDSM ,
Is your new csv file has got the same name as the first one published?
The file name needs to be exactly the same as the original file name.
MehdiPira1
@GPGeoespacialIDSM
I don't know why you're getting the type error. Your second script using feature collection should work.
Besides, The following script should work as I tested it a couple of times:
existing_table = gis.content.search("table.csv")
for item in existing_table:
    item.delete()
new_csv = gis.content.add({}, data=r"path to table.csv")
new_csv.publish(overwrite=True)
Regards
Mehdi
GPGeoespacialIDSM
Thanks for your reply. Your solution kind of works. The problem is it replaces the csv uploaded to AGO, but it doesn't touch the Hosted Table derived from this uploaded csv. My first attempt even deleted the hosted table and updated the csv.
Take a look (this time files has their real name):
gis.content.search("casos_am_MS")
Out[1]:
[<Item title:"casos_am_MS" type:Table Layer owner:geomamiraua>,
 <Item title:"casos_am_MS" type:CSV owner:geomamiraua>]
I need to update the table layer, as it is included on a map and will update a dashboard. So, if I try to update the hosted table:
existing_table = gis.content.search("casos_am_MS")[0]
    item.delete()
Out [2]
  File "<ipython-input-189-08ae4df83419>", line 2, in <module>
    item.delete()
AttributeError: 'str' object has no attribute 'delete'
Obviously, because I'm trying to do it on a list. It can't work. So I'm wondering how to access the data inside the Table Layer (hosted table). As I understand, when you upload a csv and then publish it as a hosted table they become actually independent. I can even delete the csv while the derived hosted table remains untouched and working fine.
Now I realized another issue. The csv format doesn't store column types (str, int, float, etc). So the issue ``AttributeError: 'FeatureLayerCollection' object has no attribute 'replicas'`` might be related to different schemas between the published table and the local one. I have tried to modify the column types in a pandas dataframe to match those of the published table as below, but no success at all:
casos_csv = pd.read_csv('C:\\path\\casos_am_MS.csv', sep=',')
# then I make the appropriate changes on column types and now it matches what I have on the hosted table. I'll omit the code here, irrelevant.
# trying to update with the dataframe
table_ago_FC.manager.overwrite(casos_csv)
# and I get the same error
  File "<ipython-input-195-95f07d87762a>", line 1, in <module>
    casos_ago_FC.manager.overwrite(casos_csv)
I'll attach two CSVs, an old and an updated one. With the old, you create a hosted table, with the new you try to update. If someone can test I'll appreciate it.
MehdiPira1
Your sample table csvs do not include any coordinates so cannot be mapped. Unless they are supposed to be related or joined tables to a hosted feature layer.
GPGeoespacialIDSM
@MehdiPira1  Yes, you're right. That's why it is a hosted table and not a hosted feature layer or a hosted feature collection
emedina
What you should do instead, if the hosted feature table is used in a dashboard (and since your new csv contains all previous data), is simply truncate the hosted feature table (effectively making it a skeleton table with no records) and then append records from your csv when you have updates.
I'm approximating here since I don't have an example to use, but something like this should work:
import pandas as pd
from arcgis.features import FeatureLayer
adds = casos_csv.to_dict("records")
Note: I am assuming the column names match the table schema. If this is not the case, you have to do some column renaming prior to creating the dict.
GPGeoespacialIDSM
Thanks for your reply @emedina. The approach looks promising. In the table_url variable, I'm assuming it is a rest api url. Proceeding with that assumption, I'm receiving the following error:
tbl.manager.trucate() # truncate table
  File "<ipython-input-278-4b257b2869e1>", line 1, in <module>
AttributeError: 'FeatureLayerManager' object has no attribute 'trucate'
Ideas?
emedina
Sorry, that was a typo in the code. I updated my post - the line should read:
GPGeoespacialIDSM
@emedina
Oops, my bad. I didn't notice the typo as well. Ok, tuncate works just fine. Now I have an empty table. However,
  File "<ipython-input-310-fd6df565cd97>", line 1, in <module>
  File "C:\conda\envs\covid-amazonas\lib\site-packages\arcgis\features\layer.py", line 2753, in edit_features
    return self._con.post_multipart(path=edit_url, postdata=params)
  File "C:\conda\envs\covid-amazonas\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 835, in post_multipart
    force_bytes=kwargs.pop("force_bytes", False),
  File "C:\conda\envs\covid-amazonas\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 595, in _handle_response
    self._handle_json_error(data["error"], errorcode)
  File "C:\conda\envs\covid-amazonas\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 618, in _handle_json_error
    raise Exception(errormessage)
Exception: Cannot perform operation. Invalid operation parameters.
'adds' parameter is invalid
Object reference not set to an instance of an object.
(Error Code: 400)
In any case, having an empty table is progress indeed. The documentation says:
When making large number (250+ records at once) of edits,appendshould be used over edit_features to improve performance and ensure service stability.
But by the append docs, it seems I can only do it using an already uploaded table as the source of the updated data, is that right? (docs aren't that clear about that) By reading the docs I can't realize how to append data from the adds variable we just created or from a local csv.
