Unable to import ArcGIS Python library
2208
02-02-2022 03:35 PM
sullivani
Hi, I have just started looking at using the ArcGIS API for Python library, but I have hit an issue immediately.
Attempting to import the library results in the following error:
from arcgis.gis import GIS
  File ".\main.py", line 1, in <module>
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\arcgis\__init__.py", line 4, in <module>
    from . import features, geoanalytics, geocoding, geometry
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\arcgis\features\__init__.py", line 26, in <module>
    from .feature import Feature, FeatureSet, FeatureCollection
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\arcgis\features\feature.py", line 25, in <module>
    from arcgis.gis import Layer
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\arcgis\gis\__init__.py", line 31, in <module>
    from arcgis.gis._impl._con._helpers import _is_http_url
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\arcgis\gis\_impl\_con\__init__.py", line 1, in <module>
    from ._connection import Connection
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 26, in <module>
    certifi_win32.generate_pem()
  File "C:\Users\user\PycharmProjects\sqm_arcgis\venv\lib\site-packages\certifi_win32\wincerts.py", line 113, in generate_pem
    os.makedirs(os.path.dirname(PEM_PATH))
  File "C:\Users\user\AppData\Local\Programs\Python\Python38\lib\os.py", line 223, in makedirs
    mkdir(name, mode)
FileExistsError: [WinError 183] Cannot create a file when that file already exists: 'C:\\Users\\user\\AppData\\Local\\.certifi'
I tried a number of things to solve this issue - deleting the folder and even reinstalling Python and the ArcGIS library, but still the issue occurs.
Has anybody run into the same  problem before? I only have this issue on Windows 10, I haven't had the same issue on Linux. I have even tried on multiple Windows 10 machines, which resulted in the same error each time.
Thanks
DanPatterson
MVP Esteemed Contributor
do you have the correct version installed for windows?
arcgis .... anaconda site
... sort of retired...
GeorgePovoas
Delete this file:
It worked for me!
