table.query Filter by variable
1401
01-06-2022 06:23 AM
markkellermannBWB
I have a build a date as string from yesterday:
now_dt = dt.utcnow()
yday_dt = now_dt - datetime.timedelta(days=1)
yesterday = print(yday_dt.strftime("%m/%d/%Y"))
And I want to query a table text-column "akt_datum" with a Filter: where akt_datum=yesterday:
I tried this, but it doesnt work:
q_yday=table.query(where="akt_datum = yesterday", out_fields = ["titel, typ, views, akt_datum, aenderung"]).sdf
So my question is, how works the table.query Filter with a calculated variable?
Thanks and Greets
AdminGIS2
You can use f-strings to include a dynamic variable into a string. However, it's probably easier to create a direct SQL query searching for yesterday. I've added both examples:
# your code
yesterday = yday_dt.strftime("%m/%d/%Y")
# create query with f-string
q_string = f"akt_datum='{yesterday}'"
# SQL
q_string = "akt_datum=CURRENT_DATE()-1"
q_yday=table.query(where=q_string, out_fields = ["titel, typ, views, akt_datum, aenderung"]).sdf
A final note, if akt_datum is a datetime field you may need to cast the field to DATE first for your query to work
# SQL
q_string = "CAST(akt_datum AS DATE)=CURRENT_DATE()-1"
AdminGIS2
# your code
# SQL
# SQL
