st_bin() Detail Documentation
725
03-24-2020 03:00 PM
AnamikaPaul
Hi Guys,
I am new to ESRI and trying to understand its use. I am using St_Bin() UDF on my hive tables. St_bin() assigns a bin_ID based on lat/long and distance value I pass.
my code:
st_bin(0.01,st_point(long,lat)) as bin_id
I was wondering if there is some detail documentation about the ST_Bin() UDF i can go through to understand, if its a standard value that is assigned or more of a relative evaluation.
Basically what i am trying is, if I ran the same function on 2 different dataset, will the bin_ID be same for the same/close points or will it might change for different datasets. My aim it to get a bin_id for to 2 different dataset and see if I can use this as one of my join condition between 2 dataset to reduce computation and increase the processing time.
TIA
Tags (1)
