Spatially Enabled DataFrames Returns SHAPE Eeven When Using Fields Filter
2425
11-22-2022 09:40 PM
geoca
Using ArcGIS Python API and Spatially Enabled DataFrames
import arcpy
import pandas as pd
from arcgis.gis import GIS
fc = "City.gdb\\fire_stations"
sdf3 = pd.DataFrame.spatial.from_featureclass(fc, fields=["ADDRESS","MUN_NAME"])
sdf3.head()
I am still getting the SHAPE even though I am passing `fields=["ADDRESS","MUN_NAME"]`  in the argument to get only ["ADDRESS","MUN_NAME"] in the df
Can you please let me know how I can get rid of the SHAPE column?
DanPatterson
MVP Esteemed Contributor
arcgis.features module | ArcGIS API for Python
perhaps then you don't need a Spatially Enabled DataFrames
... sort of retired...
BHeist
Agreed! You’re seeing that because you’re using a SEDF
RogerDunnGIS
If you don't want the shape column, you can call this after it's created:
sdf3.drop("SHAPE", axis=1, inplace=True)
DarrenConly
Adding to this thread, it's worth noting that if you explicitly include the SHAPE field in the list of fields you specify, it cause a TypeError. So if you're specifying a subset of fields, make sure you do not include SHAPE in that subset:
emp_fields = ['SHAPE', 'SECTOR', 'COUNT']
df_i = pd.DataFrame.spatial.from_featureclass(Path(gdb_empinv).joinpath(fc), where_clause=wherecl_emp, sr=sref_sacog, fields=emp_fields)
# Returns TypeError: Expected String or Unicode
