Spatially Enabled Dataframe to_featureclass results in NULL attributes when exporting to SDE table
1278
08-02-2021 06:00 AM
markjones6
When trying to export a spatially enabled dataframe to a feature class in SDE or as a shp, the featureclass retains it's geometry, but all attributes result in NULL values in the exported feature class.  If i perform an export to AGO using to_featurelayer, then the attributes are exported as expected.
The command used is:
test_sdf = pd.Dataframe.spatial.to_featureclass(location=**sde connection here**)
Any thoughts appreciated!
emedina
As a workaround, what happens when you convert to a featureset and then try the save method? Like this:
test_fs = pd.Dataframe.spatial.to_featureset()
test_fs.save(
    save_location="path/to/your/location",
    out_name="test"
See here for more info on the method: https://developers.arcgis.com/python/api-reference/arcgis.features.toc.html?highlight=featureset#arc...
