Spatial DataFrame to Feature Class no longer overwrites output
2913
04-05-2022 08:15 AM
JohnHuillery1
The ...spatial.to_featureclass() method no longer overwrites the existing feature class.
Sample code:
import arcpy
import pandas as pd
from arcgis.features import Feature
arcpy.env.overwriteOutput = True
df = pd.DataFrame.spatial.from_featureclass(<valid featureclass>)
#modify features in some fashion
df.spatial.to_featureclass(location=<path to existing feature class>, overwrite=True, sanitize_columns=False)
ArcGIS API for Python version 1.9.1
JianwuChen
It works for me when I am using ArcGIS Pro 3.1.0. But the column aliases of the result output feature class are all the same as column names. The column aliases of the input feature class are not kept. That is the problem.
jcarlson
Are you using the ArcGIS Pro notebook environment? There are multiple other posts on here about this issue, seems to be a recent change.
I'd suggest using a separate Python env for this outside of Pro.
- Josh Carlson
Kendall County GIS
JohnHuillery1
I use Spyder with a cloned env
jcarlson
Interesting. Recent updates to the arcgis package or arcpy? You could try rolling back to a prior version and see if it works. I'm at 2.0.0, and am able to export to feature class without issue. But then, I don't use arcpy, so I don't know if that's where people are experiencing the issue.
- Josh Carlson
Kendall County GIS
DavidAnderson_1701
I just tested with the 1.9.1 in the stand along Jupyter notebook installed with ArcGIS Pro.  Worked fine for me.
How is it failing?   Does creating a new feature class still work if you give a slightly different name?
Maybe it is slow? I had a recent, still unanswered question, noting that the export is very slow. spatial.to_featureclass is very slow in writing to... - Esri Community
JianwuChen
