socket.gaierror: [Errno 11001] getaddrinfo failed
10597
08-28-2023 05:02 AM
Labels (3)
AbdujabborMakhmudov
Greetings,
i want to overwrite feature service in portal. i followed this guide https://developers.arcgis.com/python/samples/overwriting-feature-layers/ but im getting an error at overwriting part.
from arcgis.gis import GIS
from arcgis import features
import pandas as pd
import os
from arcgis.features import FeatureLayerCollection
portal_url = "https://myportalurl"
username = "login"
password = "pass"
gis = GIS(portal_url, username, password)
fileid = '9bfb22d38bee49af93ad56952f5a4cc3'
item = gis.content.get(fileid)
# item_props = {
#     "title": "Updated title",
#     "description": "Updated description"
# item.update(
#     item_properties=item_props,
# updating is not causing any problems
new_file_path = os.path.join( os.getcwd(), "uz_thermal_points.zip")
thermal_flayer_collection = FeatureLayerCollection.fromitem(item)
thermal_flayer_collection.manager.overwrite(new_file_path)
filename is the same as original published file. in the website, there is no error while overwriting features.
i got this error:
Exception has occurred: ConnectionError
A connection error has occurred: HTTPSConnectionPool(host='esrisrv.uzspace.org', port=6443): Max retries exceeded with url: /arcgis/rest/services/Hosted/uz_thermal_points/FeatureServer/layers?f=json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000022A5D6EDC10>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
During handling of the above exception, another exception occurred:
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x0000022A5D6EDC10>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='esrisrv.uzspace.org', port=6443): Max retries exceeded with url: /arcgis/rest/services/Hosted/uz_thermal_points/FeatureServer/layers?f=json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000022A5D6EDC10>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='esrisrv.uzspace.org', port=6443): Max retries exceeded with url: /arcgis/rest/services/Hosted/uz_thermal_points/FeatureServer/layers?f=json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000022A5D6EDC10>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
  File "D:\scripts\thermal_active\from arcgis.py", line 33, in <module>
requests.exceptions.ConnectionError: A connection error has occurred: HTTPSConnectionPool(host='esrisrv.uzspace.org', port=6443): Max retries exceeded with url: /arcgis/rest/services/Hosted/uz_thermal_points/FeatureServer/layers?f=json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000022A5D6EDC10>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
 i found post which had similar problem, but solution required using request module instead of using the httplib. However, i cant control it in my case.
