republish sde data to arcgis online hosted service
3085
8
04-01-2025 06:25 AM
OfraAi
Hi everyone
I have a hosted service, containing first layer + attachments, second layer with attachments and related table to the second layer with attachments for itself.
The original data is stored in SDE.
I need to publish the whole data once a month, and overwrite the whole data, using arcgis api for python.
No change in the layers structure.
I don't want to copy the data to temp FGDB before publishing, since there a lot of picture and the volume is large..
I could not find a solution to this scenario.
(by the way, using arcpy append worked in one desktop but not in the server, and argis.append does not support attachments...)
I'll appreciate any help.
Ofra
Clubdebambos
MVP Regular Contributor
Hi @OfraAi,
First question...
Are you publishing to ArcGIS Online or Portal?
~ learn.finaldraftmapping.com
OfraAi
Hi @Clubdebambos
II'm publishing to ArcGIS Online.
Clubdebambos
Hi @OfraAi,
These are the two options I generally use.
1. No code using a referenced service. The data resides in SDE and registered with Portal through Manager Registered Data Stores. Publish the feature service to portal as a referenced service. Any edits made to the SDE feature classes are automatically applied to the service and vice versa. Add the service to AGOL using a viewer user role for AGOL users to consume (Add item in AGOL via service Portal URL). Again, any edits in Portal/SDE will automatically apply to your AGOL service.
2. Use this script to publish from ArcGIS Pro to AGOL. You add your layers to a Map and the service name will take on the name of your Map. Re-run every time you want to overwrite the hosted service in AGOL.
import arcpy
import os
## Esri Documentation:
##  https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/arcgisproject-class.htm
##  https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/map-class.htm
##  https://pro.arcgis.com/en/pro-app/latest/arcpy/sharing/featuresharingdraft-class.htm
##  https://pro.arcgis.com/en/pro-app/latest/tool-reference/server/stage-service.htm
##  https://pro.arcgis.com/en/pro-app/latest/tool-reference/server/upload-service-definition.htm
## ArcGIS Pro Version 3.2.0
## INPUT REQUIRED  #############################################################
## the path to the APRX that contains the Map with the layers to publish
aprx_path = r""
## the name of the Map in the APRX that contains the layers to publish
map_name = "MAP NAME"
## a folder to stage the definition files
staging_fldr = r""
## some tags for our Hosted Feature Service
tags = "tag1,tag2,tag3"
## a description for our Hosted Feature Service
description = "This is our description"
## a summary for our Hosted Feature Service
summary = "This is our summary"
## ACCESS ARCGIS PRO COMPONENTS  ###############################################
## access the APRX
aprx = arcpy.mp.ArcGISProject(aprx_path)
## access the correct map
m = aprx.listMaps(map_name)[0]
## STAGING #####################################################################
## the service definition filenames and output paths
sddraft_output_filepath = os.path.join(staging_fldr, f"{map_name}.sddraft")
sd_output_filepath = os.path.join(staging_fldr, f"{map_name}.sd")
## if either of the output files already exists, then delete
if arcpy.Exists(sddraft_output_filepath):
    arcpy.Delete_management(sddraft_output_filepath)
if arcpy.Exists(sd_output_filepath):
    arcpy.Delete_management(sd_output_filepath)
## MANIPULATE THE SD DRAFT ######################################################
## use the Map object getWebLayerSharingDraft method
## returns a FeatureSharingDraft object
sd_draft = m.getWebLayerSharingDraft(
    server_type = "HOSTING_SERVER",
    service_type = "FEATURE",
    service_name = map_name
## alter some properties of the sd_draft
sd_draft.description = description
sd_draft.summary = summary
sd_draft.tags = tags
sd_draft.allowExporting = True
sd_draft.overwriteExistingService = True
#sd_draft.portalFolder = "INSERT FOLDER NAME"
## create the Service Definition Draft file
sd_draft.exportToSDDraft(sddraft_output_filepath)
## STAGE THE SERVICE ###########################################################
## stage the service
arcpy.server.StageService(
    in_service_definition_draft = sddraft_output_filepath,
    out_service_definition = sd_output_filepath
## PUBLISH TO ARGIS ONLINE #####################################################
## publish to agol
arcpy.server.UploadServiceDefinition(
    in_sd_file = sd_output_filepath,
    in_server = "HOSTING_SERVER"
print("\nSCRIPT COMPLETE")
Original blog post here.
Edit: For the ArcPy approach, make sure you are signed into AGOL in Pro or use the below.
arcpy.SignInToPortal(portal_url,username,password)
Please le us know if either of these suit.
All the best,
Glen
OfraAi
Hi @Clubdebambos Glen,
I'll try this script right now, although it uses arcpy to access arcgis online, and I'm not sure it will work. See my other comment to MikeVolz
Thank you, I'll update soon
Ofra
MikeVolz
Can you provide the python append that you tried to use?
OfraAi
Hi @MikeVolz ,
By this article, and a case I've opened, and an existing enhancement (ENH-000131471, ENH-000173902), python api for arcgis append does not honor attachments.
Regarding using arcpy, I had problem reaching arcgis Online from different computers.
I have this script to check it, and any arcpy command can by used.
import arcpy
from arcgis.gis import GIS
print('connecto to Online')
username = 'username '
password = 'password'
gis = GIS(OnlineURL, username, password)
print('Connected User: ' + gis.users.me.username)
item_id = '1111111111'
O_Feature_Service = gis.content.get(item_id)
O_layer = O_Feature_Service.layers[0]
O_layer_url = O_layer.url
print(O_layer_url)
Olyr_query_result = O_layer.query(out_fields = ["GlobalID"])
print('arcgis: ' + str(len(Olyr_query_result.features)))
s = arcpy.SignInToPortal(OnlineURL,username,password)
layer =arcpy.management.MakeFeatureLayer(O_layer_url + "?token="+ s["token"], "aaa").getOutput(0)
print('arcpy: ' + str(arcpy.GetCount_management(layer)[0]))
print('end')
Good result returns the number of features using python api and arcpy.
Bad result returns the number of features using python api but when using any arcpy command I get an erro: Parameters are not valid. error 732 Dataset https:.... does not exist or is not supported. Failed to execute.
If you have any idea why it works only on several computers and gives error on others - it would be great.
Both computers has python version 3.11.8
Ofra
Clubdebambos
Hi @OfraAi,
Have you tried without the "token"? If they have ArcGIS Pro installed and access to ArcPy, they more than likely don't need a token.
You don't need to MakeFeatureLayer to get the feature count, just access the URL directly.
import arcpy
fl = "https://services-eu1.arcgis.com/*****/arcgis/rest/services/County Boundaries/FeatureServer/0"
## Or
# fl = O_layer.url
feature_count = arcpy.management.GetCount(fl)
print(feature_count)
>>> 26
OfraAi
@Clubdebambos
The attached script just demonstrates the problem I had using arcpy with ArcGIS Online.
I've found the difference between the different environment, and it seems to be the definition of temporary storage.
when I've added:
arcpy.CreateScratchName(workspace=arcpy.env.scratchGDB)
it works.
Now I have to implement this in the whole script.
I'll update.
Thanks anyway
Ofra
