Remove characters in string using a variable
2422
09-16-2022 08:22 AM
jaykapalczynski
Honored Contributor
I am trying to remove characters from a string but this Numeric value changes.
I'm passing in the string and the number of characters that should remain.
Below there are two ways I am trying this both doing the same thing... But the number of characters is hardcoded '75'
How do I replace the '75' with the variable 'characterLength' that is being passed into the def???
newmod2 = newmod1[: {characterLength} ]
def fModifyValue(processResults, charlength):
        initialMod = str(processResults)
        characterLength = charlength
        newmod1 = initialMod.replace("u'", "")
        newmod2 = (newmod1[:75] + '..') if len(newmod1) > 75 else newmod1
        #OR
        newmod2 = newmod1[:75]
        return newmod2
jaykapalczynski
Honored Contributor
Ok think I got it.... BUT please if there is a better way please let me know.
        characterLength = int(charlength)
        newmod1 = initialMod.replace("u'", "").replace('[', '').replace(']', '').replace(r"'", r'')
        newmod2 = newmod1[:characterLength]
        return newmod2
jaykapalczynski
Honored Contributor
Maybe
newmod2 = newmod1[: {} ].format(characterLength)
UPDATE:  Nope that does not work
jaykapalczynski
Honored Contributor
        return newmod2
JoshuaBixby
MVP Esteemed Contributor
Besides the variable length slicing, which you appear to have figured out, what exactly are you trying to do with all of those replace statements?
jaykapalczynski
Honored Contributor
The data is coming in from a Word Press RestEP and a bit messy...
DavidAnderson_1701
Regular expressions are your friend here.  Check out the re module.
