Python project call crashing out
4533
6
10-03-2021 04:20 AM
IanHamilton2
I am unable to get this call to project a point to complete.
I am connecting to an enterprise portal from an arcgis install at home through Jupiter labs. I have been successfully connecting using a client  Id I created through the enterprise portal web interface. See below. I am unable to project any data (other calls to get featureLayer etc all have worked so far). Exceptions attached. It appears that the code is trying to guess my connection, but should already have this information in the gis I create.
Would anyone have any idea what is going wrong?
from arcgis import geometry
from arcgis.geometry import Point, project, find_transformation
from arcgis.gis import GIS
gis = GIS("https://myurl.com/portal",client_id="xyz")
ptwebm = Point({"x" : 17041106.13569748, "y" : -3183137.706970891})
result = project(geometries=[ptwebm],in_sr = 3857,out_sr = 4326,gis=gis)
Ian
DavidPike
MVP Notable Contributor
Hi Ian,  Your attached image is unfortunately unreadable (for me at-least).
MehdiPira1
@IanHamilton2 ,
I don't why you're getting this error as the attached screenshot is small and blurry.
You could also try the normal log into Portal and see if it works out the projection:
gis = GIS("https://myurl.com/portal", "username", "password", verify_cert=False)
IanHamilton2
Sorry about the log.
Thanks for your help. I have tried using my username and password but there is 2 factor authentication to contend with  - from home I am not getting a code. So I used the client id method instead.
I guess this is a bug, otherwise why would I be able to connect and access feature services etc but no be able to use some of the API
 here us the text
Exception                                 Traceback (most recent call last)
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/_impl/tools.py in __init__(self, url, gis)
    329                     try:
--> 330                         self._token = self._con.generate_portal_server_token(url)
    331                     except Exception as e:  # GUESSED Auth Wrong, try anonymously
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/gis/_impl/_con/_connection.py in generate_portal_server_token(self, serverUrl, expiration)
   1738         else:
-> 1739             resp = self.post(   1740                 path=self._token_url, postdata=postdata, ssl=True, add_token=False
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/gis/_impl/_con/_connection.py in post(self, path, params, files, **kwargs)
   1040         retry_count = 0
-> 1041         return self._handle_response(   1042             resp=resp,
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/gis/_impl/_con/_connection.py in _handle_response(self, resp, file_name, out_path, try_json, force_bytes)
    594                 errorcode = data["error"]["code"] if "code" in data["error"] else 0
--> 595                 self._handle_json_error(data["error"], errorcode)
    596             return data
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/gis/_impl/_con/_connection.py in _handle_json_error(self, error, errorcode)
    617         errormessage = errormessage + "\n(Error Code: " + str(errorcode) + ")"
--> 618         raise Exception(errormessage)
    619
Exception: client_id not specified
(Error Code: 400)
During handling of the above exception, another exception occurred:
RequestException                          Traceback (most recent call last)
<ipython-input-6-63ef118dd7a8> in <module>
      1 ptwebm = Point({"x" : 17041106.13569748, "y" : -3183137.706970891})
----> 2 result = project(geometries=[ptwebm],in_sr = 3857,out_sr = 4326,gis=gis)
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/geometry/functions.py in project(geometries, in_sr, out_sr, transformation, transform_forward, gis, future)
    947     if gis is None:
    948         gis = arcgis.env.active_gis
--> 949     return gis._tools.geometry.project(    950         geometries, in_sr, out_sr, transformation, transform_forward, future=future
    951     )
~/opt/anaconda3/lib/python3.8/site-packages/arcgis/_impl/tools.py in geometry(self)
  17106             else:
  17107                 svcurl = self._gis.properties["helperServices"]["geometry"]["url"]
> 17108             self._geometry = _GeometryService(svcurl, self._gis)
  17109             return self._geometry
  17110         except KeyError:
  15420
  15421     def __init__(self, url, gis=None):
> 15422         super(_GeometryService, self).__init__(url, gis)
  15423
  15424     @classmethod
    352                             from requests.exceptions import RequestException
    353
--> 354                             raise RequestException(str(e))
    355                 else:
    356                     self._token = self._con.token
RequestException: client_id not specified
(Error Code: 400)
IanHamilton2
My apologies. The call with user name and password does not work for me as there is 2 factor identification at work and I am trying to connect from home.
here is the log
    329                     try:
   1738         else:
    596             return data
    619
(Error Code: 400)
    947     if gis is None:
    951     )
  17106             else:
  15420
  15423
  15424     @classmethod
    353
    355                 else:
(Error Code: 400)
IanHamilton2
 here us the text
    329                     try:
   1738         else:
    596             return data
    619
(Error Code: 400)
    947     if gis is None:
    951     )
  17106             else:
  15420
  15423
  15424     @classmethod
    353
    355                 else:
(Error Code: 400)
IanHamilton2
Apologies, here is another attempt. I cannot log in using a user and password as there is 2 factor authentication enabled on my account. This is not sending a code when trying to work from home, with or without a certificate.
