Python List object to varaibles.
1603
01-21-2024 09:23 AM
kapalczynski
I have this List object and need to massage it a couple ways...
First I would like it to read without the {'attributes':  at the front and the trailing }
Like this:
{'OBJECTID': 2, 'PERMITTEE': None, 'ROUTE': None, 'GLOBALID': '{8BF971DC-473B-4C88-8007-363EDAE7D091}', 'RELGLOBALID': '{F06AD758-9BBB-4096-942D-484F9F2B0435}', 'INSPECTOR_NAME': None, 'PERMIT_INTERNAL_ID': None}, 'geometry': {'x': -77.393420655, 'y': 37.615990732}
Second I would like to be able to set the OBJECTID, PERMITID, ROUTE etc to variables...
Thoughts?
{'attributes': {'OBJECTID': 2, 'PERMITTEE': None, 'ROUTE': None, 'GLOBALID': '{8BF971DC-473B-4C88-8007-363EDAE7D091}', 'RELGLOBALID': '{F06AD758-9BBB-4096-942D-484F9F2B0435}', 'INSPECTOR_NAME': None, 'PERMIT_INTERNAL_ID': None}, 'geometry': {'x': -77.393420655, 'y': 37.615990732}}
DanPatterson
MVP Esteemed Contributor
dictionary... not list, check python documentation for more information.  Dictionaries have 'keys' and 'values' and they can be 'sliced'
d = {'attributes': {'OBJECTID': 2, 'PERMITTEE': None, 'ROUTE': None, 'GLOBALID': '{8BF971DC-473B-4C88-8007-363EDAE7D091}', 'RELGLOBALID': '{F06AD758-9BBB-4096-942D-484F9F2B0435}', 'INSPECTOR_NAME': None, 'PERMIT_INTERNAL_ID': None}, 'geometry': {'x': -77.393420655, 'y': 37.615990732}}
d.keys()
Out[2]: dict_keys(['attributes', 'geometry'])
d['attributes']  # -- slice by the key
{'OBJECTID': 2,
 'PERMITTEE': None,
 'ROUTE': None,
d['attributes']['GLOBALID']
... sort of retired...
kapalczynski
I guess my question is how to I access the Attribute Key and the Geometry Key and write their objects to variables.
This is what I am doing right now and ... querying a dataset and writing to json file and trying to read that and put into variables
unless there is a better way?
    URL = targetURL + '/query'
    field = 'OBJECTID'
    whereclause = 'OBJECTID=2'
    PARAMS = {'token': portaltoken,'f': 'json', 'where': '{}'.format(whereclause), 'returnIdsOnly': False, 'returnCountOnly': False, 'returnGeometry': True,
                  'outFields': '*'}
    r = requests.post(url=URL, data=PARAMS)
    outjsonpath = outputVariable + "output.json"
    layer_data = r.json()
    layer_data_final = layer_data
    print('Writing JSON file...')
    with open(outjsonpath, 'w') as out_json_file:
        json.dump(layer_data_final, out_json_file)
    filetoImport = outjsonpath
    f = open(filetoImport)
    data = json.load(f)
    featureAddingAdd = data['features']
    print(featureAddingAdd)
DanPatterson
d.keys()
{'OBJECTID': 2,
 'PERMITTEE': None,
 'ROUTE': None,
kapalczynski
@DanPatterson  Cheers.... thanks for the correction and guidance... much appreciated.
