Python - Get the services layers used in a Portal Dashboard
2798
06-29-2023 04:09 AM
Labels (2)
Alex2
Hi there!
I'm trying to get all the services, layers, webmapps...etc, that are dependent between each other in my organization via python.
I can get this information of diferent elements using the method "dependent_upon()" and "dependent_to()", but it does not retrieve this information for some elements, such as Dasboards or some aplications.
Is there a way to get which features services are consumed by a dashboard via python?
Thanks!
jcarlson
If you use the get_data method on the dashboard Item, you can search through the JSON and find all referenced layers.
from arcgis.gis import GIS
import re
gis = GIS('your portal url')
# get dashboard json
dash = gis.content.get('itemid of dashboard').get_data()
# pull out all itemids of maps / data layers w/ regex; push unique values into list
matches =  []
[matches.append(m) for m in re.findall('[a-f0-9]{32}', str(dash)) if m not in matches]
Once you have your matches list, you can do other things with it, like pull the URLs or titles.
- Josh Carlson
Kendall County GIS
jcarlson
import re
matches =  []
- Josh Carlson
Kendall County GIS
maya_fromstein
Hi! Sorry, joining the party very late.
Would you mind explaining how that regex expression (in line 11 of your code) accesses the itemIds? I am still a python newb and so still struggle with regex, sorry if this is obvious.
Very much appreciate your help, thanks!
jcarlson
You should check out regex101.com, it has loads of resources for understanding regex. But here's the plain English version.
[a-f0-9] : Match a single character from a-f or from 0 to 9. ItemIDs are hexidecimal, so they can have digits and the first 6 letters of the alphabet.
{32} : Whatever precedes this, match it 32 times.
So, it should find any 32-character line of text consisting of digits, a, b, c, d, e, or f. Which is an ItemID!
- Josh Carlson
Kendall County GIS
Alex2
Thank you Josh!  This code helped me a lot.
