Python API add group layer to webmap?
4190
10-28-2021 07:58 AM
RichardReinicke
map_item["operationalLayers"]
I have a very general question this time.
The Esri arcgis API is meant to be THE tool to automate workflows and to interact with ArcGIS Portal. But there seem to be a lot of features that are not implemented yet, in my case map authorization.
I have the new webmaps (next gen) and map viewer beta. I can interact with web maps v2 also from the Python API. But I can't create a group layer with API methods.
I can do:
map_item.get_data()
I see my GroupLayer in the map layers:
        "id": "htsews6tyu0-layer-10010",
        "title": "DummyGroup",
        "layers": [
                "id": "17cc733308b-layer-3",
                "title": "FeatureLayer1",
                "url": "some-feature-server-url",
                "itemId": "d77d046fb6de424da2258a08b376f1fc",
                "layerType": "ArcGISFeatureLayer",
                "popupInfo": {
                    "popupElements": [
                            "type": "fields"
                    "showAttachments": True,
                    "fieldInfos": [
                            "fieldName": "objectid",
                            "label": "OBJECTID",
                            "visible": False
                    "title": "Titel1"
                "id": "17cc7332022-layer-2",
                "title": "FeatureLayer2",
                "itemId": "3efe6ee7327e49e59a37406f622db492",
                "popupInfo": {
                    "popupElements": [
                            "type": "fields"
                    "fieldInfos": [
                            "visible": False
                    "title": "Titel2"
        "layerType": "GroupLayer"
Now I can get portal Feature Service items and it's FeatureLayer items and I want to:
1. add another Feature Layer to map_item["operationalLayers"][0]["layers"]
2. or add another group layer with x feature layers
We really need operations for the Python API to compose a webmap and its layers from existing layer items.
RichardReinicke
I've been able now to accomplish my goal and to add a new group layer with existing feature layers to my web map item. Unfortunatly for this you need to write dictionaries that correspond to Esri web map specification (GroupLayer, FeatureLayer ... )
https://developers.arcgis.com/web-map-specification/objects/groupLayer/
Here are the major parts:
def create_layer_id(layerIndex):
    return ''.join(random.choices(string.ascii_lowercase + \
        string.digits, k=11)) + "-layer-" + str(layerIndex)
# This is my base webmap (template)
map_template = gis.content.get('3095cb51e2a44e818b90608c487f8b3b')
# Copy template to new web map item into subfolder
project_map = WebMap(map_template).save({
    "title": "project map",
    "snippet": "some description",
    "tags": "maps"}, folder="project_folder")
# Create a new group layer following esri web map specification
group_layer = {
    "id": create_layer_id(random.randint(10000, 99999)),
    "layers": [],
    "layerType": "GroupLayer",
    "title": "my new group layer" }
# Get an existing feature service / layer collection item
# get_item() is standard portal item query logic
lyr_item = get_item(lyr_name, "Feature Service", "test")
# Create feature layer following esri web map specification
feature_layer = {
    "url": lyr_item.layers[0].url,
    "title": lyr_item.layers[0].properties.name,
    "itemId": lyr_item.id,
    "layerType": "ArcGISFeatureLayer" }
# Add feature layer to group layer
group_layer["layers"].append(feature_layer )
# Update project map with new group layer
map_def = project_map.get_data()
map_def["operationalLayers"].append(group_layer)
project_map.update({'text': str(map_def)})
Maybe this will help someone 🙂
RichardReinicke
group_layer = {
    "layers": [],
feature_layer = {
Scoth
Do you know if the layer id has to be unique? If so, it seems like the randint function wouldn't be the best option, even though it will probably work.
Cara_Walter
Thanks for posting this. It helped me a lot.
I did find that the layer will just get assigned a layer id if you do not supply one, and that seemed to be more compatible. I used this on an existing web map, and found that it worked better if I added an empty group layer and updated the web map first, then acquired the updated map definition and appended my new layers.
