PEP 561 compliant stub package for arcpy
2483
02-18-2022 10:03 AM
JanetWilson
Does anyone know if there is a PEP 561 compliant stub package for arcpy?
I'm wanting to use static typing (mypy), but Esri say they don't have type hints for arcpy.
DanPatterson
MVP Esteemed Contributor
esri produces arcpy and producing type hints probably isn't on the radar, especially with python 3.7 being the current distribution
... sort of retired...
JanetWilson
Sorry for late reply, Dan. Didn't see your reply.  Why do you say "especially with python 3.7...".. why wouldn't python 3.7 use mypy?
DanPatterson
Janet, I didn't say it wouldn't, I was referring to the stagnant python 3.7 which is being deprecated by many packages, like numpy etc.  python 3.9 (wild guess) will be the replacement.  If you examine the existing code base within esri scripts (eg C:\... your_install_folder ...\Resources\ArcToolBox\Scripts, you not find any type hints or *.pyi files let alone detailed documentation.  It keeps the python code base smaller obviously.
JanetWilson
OK, thanks.
