Not Able to Get Service Layers From ArcGIS API for Python
3836
8
05-16-2024 12:10 PM
BHK
I am trying to get list of Layers from a Service using this code
from arcgis.gis import GIS
from arcgis.gis.server import Server
from arcgis.features import FeatureLayerCollection
gis_servers = gis.admin.servers.list()
server1 = gis_servers[0]
fservices = server1.services.list(folder='GDPServices')
for service in fservices:
        layer = FeatureLayerCollection(service.url)
        print(layer)
but I am  receiving this error message
AttributeError: 'PropertyMap' instance has no attribute 'layers'
Can you please let me know why this is happening and how I can fix this?
EarlMedina
The problem here is that you're getting the admin url for those services (which is not what you want to be using). They come back in the format: https://server.domain.com/server/admin/services/serviceName.MapServer
If you're not doing any Server administration then it would be better to just use gis.content, I'd say.
However, if you must stick with the Server submodule, then I think you can do so by changing your code to:
fservices = server1.content.list(folder='GDPServices')
There is a catch - content.list doesn't have filtering built in beyond the folder and will try to initialize objects (this may be a slow process) from the services for you. So, unless you are certain all you have in there are Feature Services, I would recommend setting the as_dict param to True and getting only what  you need:
server.content.list(folder="Hosted", as_dict=True)
This adds extra work as you will need to filter for feature services and then concatenate the expected urls from the services directory url and content urls. So again, unless there's a reason you need to be using the Server submodule, probably using gis.content is going to be easier for whatever you're doing.
EarlMedina
BHK
Thanks @EarlMedina
It is working now but when trying this server.content.list(folder="GDPService", as_dict=True)
I am getting  this error
TypeError: list() got an unexpected keyword argument 'as_dict'
EarlMedina
Might be a version problem? I am on 2.3.0.1 and it works fine.
BHK
and this 2.3.0.1 is version of what?
EarlMedina
sorry, the version of the API.
BHK
Very silly question but where can I find the in used API version? is it the one compatible with Pro version?
EarlMedina
There's a few ways you can do this. You can either check the Pro Package Manager (arcgis), run "conda list" and check the arcgis package version, or in code like this:
import arcgis
print(arcgis.__version__)
BHK
Thanks a lost @EarlMedina
My version then is 1.8.3 and maybe that why I was getting that error
By the way, can I ask you to kindly take a look at this Post too. I
Issue on Listing Service Service Workspaces Inform... - Esri Community
I need to get the service workspace information but not shore it is doable by ArcGIS API for Python. Thanks again
