Not Able to Get Portal Null Contents Item ID using ArcGIS API for Python
2403
07-29-2024 12:47 PM
BHK
Using ArcGIS Enterprise 10.9.1 Sharing API I am able to see some `null` type items in my portal
but when I try to get these items through ArcGIS API for Python like this
username = "PortalUserXXX"
item_type = 'null'  # This represents null type
# Search for items
items = gis.content.search(query=f'owner:{username} AND type:"{item_type}"', max_items=1000)
# Print the retrieved items
for item in items:
    print(f'Title: {item.title}, ID: {item.id}, Type: {item.type}')
I am not getting anything in return.
I even tried this
item_type = None  # This represents null type
and same result! I tried this
item_type = ''  # This represents null type
which is returning all items BUT not the Null one! Can you please let me know what I am doing wrong and what I am missing here?
Brian_Wilson
Honored Contributor
I expect something with type set to null to be broken.
Have you tried accessing it with the id, since you appear to have that?
id = "SET THIS TO AN ID"
item = gis.content.get(id)
And also maybe this would work?
items = gis.content.search(query=f'owner:{username}', max_items=1000)
for item in items:
  if not item.type:
BHK
Hi Braian
Thanks for reply. on first code
id = "647f546a463e474e9abf0211f4d4ccfe"
I am getting this error message:  Unable to find ItemInfo for item '647f546a463e474e9abf0211f4d4ccfe' (Error Code: 500)
your second submitted  snippet also is not returning anything
Brian_Wilson
Honored Contributor
It's just a broken service. If you can look in your Portal server "contents/items" folder, you can find the folder that has the name matching the ID and look inside.  For example on my server it's in C:\arcgis\arcgisportal\content\items.
There will be a folder there for each item and you could open the folder and look inside. For instance on my server I could look in folder "b87919419f6c4cd4a1580085f58b0c8f" and for this service there is a folder "esriinfo" and in there is "iteminfo.json" and I could dump the contents of that file in a readable way and I'd see this
$ python -m json.tool < iteminfo.json
    "culture": "en-US",
    "name": "Clatsop_County_Locator",
    "guid": "",
    "catalogPath": "",
    "snippet": "Locator based on E911 address points, points of interest, parcels, and roads",
    "description": "Locator based on E911 address points, points of interest, parcels, and roads",
    "summary": "Locator based on E911 address points, points of interest, parcels, and roads",
    "title": "Clatsop_County_Locator",
    "tags": [
        "Clatsop",
        "County",
        "address",
        "locator",
        "geocode"
    "type": "Geocoding Service",
    "typeKeywords": [
        "Tool",
        "Service",
        "Locator Service",
        "ArcGIS Server"
    "thumbnail": "",
    "url": "",
    "minScale": 0,
    "maxScale": 0,
    "spatialReference": "",
    "accessInformation": "",
    "licenseInfo": ""
In your case, well, it might tell you all about a service that used to work but is now broken, and probably you will have to delete the item folder and then reindex your Portal to make it go away.
But if you are not comfortable doing that then you should put in a request to Esri help desk instead of trusting some random guy on Community who is retiring in less than 3 days. LOL (YAY YAY)
Brian_Wilson
Honored Contributor
I should add, if you cannot find the item folder at all or the folder is empty then you can probably jump right to part two, reindex your portal. It is relatively harmless to do but makes the Portal unavailable for a few minutes.
To reindex you log into your Portal Admin site, go to System, Indexer, and click Reindex.
The portal admin site is found at the same URL as the home page for your Portal but you replace "home" with "portaladmin" for example
https://bhk.somewhere.com/portal/portaladmin
