Not Able to Get Portal Item Properties and Resource Using ArcGIS API for Python
1846
01-12-2024 05:58 PM
BHK
Having an array of Portal Items like
p_items = ['9912a5ec3325460ab88010cfefddwr21',
           '9251s4de1s1460ab88010cfe64seyus',
           'ssdf2a5ec3325541dgs10cfefd21syx'
I need to retrieve two properties of   Type of Items weather is (Feature Layer (hosted, view) ,or  Feature Layer (hosted), or Map Image Layer )
and also, the URL referring into the source (ArcGIS Server Feature Service)
I already tried this
for item in p_items:
    item_id = item
    p_item = gis.content.get(item_id)
    item_resource = p_item.resources.list()
but the `item_resource` is always empty! Can you please let me know what I am missing here and how I can achieve this?
Clubdebambos
MVP Regular Contributor
Hi @BHK
You get this information from the JSON of the item object. Run the code below to print out the properties of an item.
from arcgis.gis import GIS
import json
agol = GIS("home")
item_id = "ITEM_ID"
item = agol.content.get(item_id)
print(json.dumps(dict(item), indent=4))
In the type and typeKeywords you will find the information your are looking for. It is not always obvious but your Feature Service and View will be of type Feature Service, the view will have a typeKeyword of View Service in the list. The Map Image Layer will have a type of Map Service. Use the below to print out the type and typeKeywords properties for an item and the url.
import json
agol = GIS("home")
p_items = ["ITEM_ID1", "ITEM_ID2", "ITEM_ID3"]
for item_id in p_items:
    print(item["type"])
    print(item["typeKeywords"])
    print(item["url"])
This link is useful for type and typeKeyword combinations: https://developers.arcgis.com/rest/users-groups-and-items/items-and-item-types.htm
~ learn.finaldraftmapping.com
Clubdebambos
Hi @BHK
import json
agol = GIS("home")
item_id = "ITEM_ID"
import json
agol = GIS("home")
    print(item["type"])
    print(item["url"])
RandyMcGregor_BMcD
I found this works with layers but not with items.
