'NoneType' object has no attribute '_tbx'
1296
01-06-2024 10:52 AM
Labels (2)
ElizmayVos
I have been trying to run the code on this page in a notebook;
https://developers.arcgis.com/python/guide/part2-find-routes/
it worked fine until I got to this section:
With output_name specified
I got this error using the exact code on this page.
I installed my API with ArcPro and run it from VS Code the other code before this worked just fine.
This GIS does not support spatial analysis.
AttributeError Traceback (most recent call last)
<timed exec> in <module>
c:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\use_proximity.py in plan_routes(stops_layer, route_count, max_stops_per_route, route_start_time, start_layer, start_layer_route_id_field, return_to_start, end_layer, end_layer_route_id_field, travel_mode, stop_service_time, max_route_time, include_route_layers, output_name, context, gis, estimate, point_barrier_layer, line_barrier_layer, polygon_barrier_layer, future)
    1554 }
    1555 params = inspect_function_inputs(
->1556 fn=gis._tools.featureanalysis._tbx.plan_routes, **kwargs
    1557 )
    1558 params["estimate"] = estimate
AttributeError: 'NoneType' object has no attribute '_tbx'
DavidPike
MVP Notable Contributor
What type of AGOL account do you have?  All the right privileges/user types and role?  credit usage, Data Editor, Creator etc.?
ElizmayVos
ArcGIS for personal use license, Administrator, Organization on ArcGIS Online.
I use my Username and Password to connect to ArcGIS.com
AbeCoughlin
I get the same error when trying to add an item to my Portal, as per the documentation.
gis_saml.content.add(item_properties = {"type": "Feature Collection","title" : "US Hurricane Data","tags": "Hurricanes, Natural Disasters, USA","description" : "Aggregated USA Hurricane Data for 2020","commentsEnabled" : False})
I'm working from Pro 10.9.1 (Python environment cloned and updated) to Enterprise 10.9.1.
As I'm new to the API I presumed I'm doing something wrong..., but possibly there's more to this issue?
