New Machine, can't debug in Visual Studio 2017 Pro with ArcGIS API for Python
2861
04-02-2021 10:45 AM
JoeWeyl
I have a new laptop and I am able to run code in Visual Studio for managing our environment (Portal/AGOL) that someone else wrote and debugged, but when I attempt to debug it I get a bunch of Visual Studio python based errors. I have searched to try and figure out where the problem is, but maybe the issue is I am not that good with the IDE and I don't have the Python parts configured correctly? I am not sure where to look to fix this?
Here is what I get in the output window, there are more errors after these but it appears they are cascading from this error?  My global default Python environment is set to 3.6 as that is where I have the ArcGIS module installed in my solution.
File "C:\Program Files (x86)\Microsoft Visual Studio\Shared\Python36_64\lib\site-packages\terminado\management.py", line 23, in <module>
from ptyprocess import PtyProcessUnicode
ModuleNotFoundError
No module named 'ptyprocess'
HenryLindemann
Hi @JoeWeyl, yes very annoying bug, just delete the terminado module, then the debugging will work.
Regards
Henry
DavidPike
MVP Notable Contributor
No idea what ptyprocess is, but I guess it's being imported in the script? Have you tried just a pip install of ptyprocess?
HenryLindemann
Regards
Henry
JoeWeyl
@HenryLindemann  I had no idea what that module was, but that was the ticket. Thank, this has been driving me nuts!
