Microsoft OneDrive Data
811
10-12-2025 05:04 PM
JohnMcGlynn
I have used 'arcpy.conversion.TableToExcel' to successfully write a spreadsheet to a location on MS OneDrive.
However, when I try to open the spreadsheet (using subprocess.Popen) it tells me the file does not exist. I think this is because the OneDrive file is synchronised to the local disk.
I think I can use the python MS Graph library to get a token for the file and then somehow synchronise it, but this python library is not present in the ESRI Python library set.
I can copy the file from OneDrive to my local disk using shutil, but I only want to do that for files on OneDrive.
Does anyone know of a way to identify OneDrive data and then synchronise it to the local disk using available ESRI Python libraries?
Tags (1)
DanPatterson
MVP Esteemed Contributor
Better OneDrive support is coming, but in the interim use it for backups of data and not a source/destination of data.
Cloud storage services, such as Microsoft OneDrive and Google Drive, are not supported unless stated otherwise in the documentation about specific tools and functionality.
... sort of retired...
