Map center is not working
1151
10-27-2022 03:22 AM
LarsChristianØstgaard
Hi
I have the same problem every time I try to display a map in Python. Im using Notebook inside CS code.
The map is drawn but the center is not where I specified it to be.
Also the defined polygon is not displayed dispite I wrote the code to display it.
The map is displayed but not the polygon and the map center is wrong, se the attached image.
Can someone see if I did something wrong?
#Import modules
from arcgis.gis import GIS
from arcgis.geocoding import geocode
from arcgis.geometry import lengths, areas_and_lengths, project
from arcgis.geometry import Point, Polyline, Polygon, Geometry
import pandas as pd
#Connect to GIS
gis = GIS('home')
#Create a Polygon object
polygon1 = Polygon({'spatialReference': {'latestWkid': 4326},
                'rings': [[[-97.06587202923951, 32.75656343500563], [-97.07033522518535, 32.75454232619796],
                           [-97.07179434702324, 32.75443405154119], [-97.073596791488, 32.75475887587208],
                           [-97.07501299810983, 32.75475887587208], [-97.07492716677937, 32.75616643554153],
                           [-97.07595713555828, 32.75602207118053], [-97.07115061698558, 32.75887321736912],
                           [-97.06930525730476, 32.75890930713694], [-97.06479914614289, 32.75739351976198],
                           [-97.06587202923951, 32.75656343500563]]]
polygon1
#Display the Polygon on a map
map3 = gis.map('2201 E Road to Six Flags St, Arlington, TX 76011, United States')
map3.basemap = "topo"
map3.zoom = 16
map3.center = {'x': -97.05815464365813, 'y': 32.75494892021667,
               "spatialReference" : {"wkid" : 4326}}
#Draw the map
map3
#Draw the Polygon on the map
map3.draw(polygon1)
Joanna_Jaczewska
I have a similar problem with the 'center' function - it does not change the map parameters
