Looking for samples to check if a point is located inside a polygon
878
07-30-2024 01:05 PM
SanchezNuñez
Good afternoon,
I am looking to create a service in Python (Geoservice) that will run in ArcGIS Portal and reads a point (customer) and returns the name of the area where the customer is located (parcel)
Two cases:
1) compare point with polygon
2) compare point with point (centroid)
Thanks
David_McRitchie
Hey Sanchez,
The following thread might be of use and provides a useful code sample.
In regards to comparing generated points with the polygon centroid I would build a feature class with centroids first using the Feature to Point tool in ArcPy. From there it depends what you want to compare exactly but for something like distance the Near tool is suitable.
Hope that helps,
David
Esri UK -Technical Support Analyst
