Large Point Feature Class: Fastest Way To Transfer Field Values From Overlapping Polygon
1359
09-04-2025 02:06 AM
Philip_Sarnecki
I have a large point feature class (<2Mill features) and a polygon feature class consisting of multiple polygon features.
The points and polygons overlap.
I'd like to write the polygon field values into their overlapping point features.
Example:
Point feature A lies within polygon feature B -> Write respective value from polygon field "name" into point field "area_name".
What is the fastest way to do this with a python script?
So far i have tried two python scripts:
- Spatial Join (Intersect) -> Join the output with the point feature class -> transfer values using field calculator (from joined field "name" to field "area_name") -> remove join
- Iterate over the polygon (using cursor), in each iteration create a new layer of the current polygon (in memory) -> select overlapping points using location based selection -> write values into selected points
Both methods take too long.
I was thinking about using a Spatially Enabled Dataframe, would this get my task done faster?
DanPatterson
MVP Esteemed Contributor
How does a standard
Intersect (Analysis)—ArcGIS Pro | Documentation
or
Pairwise Intersect (Analysis)—ArcGIS Pro | Documentation
compare speed-wise?
You would get a new featureclass with both sets of fields.  Rather than using a field calculator to update a field, perhaps deleting unnecessary fields might be faster (with a rename if it is really necessary)
Delete Field (Data Management)—ArcGIS Pro | Documentation
Alter Field (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
Philip_Sarnecki
Oh sorry, i forgot to mention, the original point feature class cannot be replaced. It may be edited but the file itself cannot be deleted or replaced
JakeSkinner
Esri Esteemed Contributor
@Philip_Sarnecki you may get better performance using an Update Cursor rather than the field calculator.  Ex:
import arcpy
pointFC = r"C:\temp\test.gdb\points"
polygonFC = r"C:\temp\test.gdb\polygons"
# Perform Spatial Join
spatialJoinFC = arcpy.SpatialJoin_analysis(.....)
# Create lookup dictionary
nameDict = {}
with arcpy.da.SearchCursor(spatialJoinFC, ["uniqueId", "area_name"]) as cursor:
    for row in cursor:
        nameDict[row[0]] = row[1]
del cursor
# Update point feature class
with arcpy.da.UpdateCursor(pointFC, ["uniqueId", "name"]) as cursor:
    for row in cursor:
        row[1] = nameDict[row[0]]
        cursor.updateRow(row)
del cursor
Clubdebambos
MVP Regular Contributor
Dictionaries and Update Cursors are also my preferred approach when updating a dataset based on another, avoiding joins and field calculator.
~ learn.finaldraftmapping.com
