Instantiate TIN as Layer object - arcpy
1505
03-16-2017 08:42 AM
martinaraffellini
Hello! the following commands works with shapefiles and rasters, but i cannot manage with a TIN.
Do you know the reason?
tin = C:\PROJECT\mytin
arcpy.CreateTin_3d(tin, CoordSys, Input_Features)  # coord sys and input defined above
mylayer = arcpy.mapping.Layer('{0}'.format(tin))
I get an error: invalid data source.
So i tried to save the TIN as a .lyr files first with arcpy.SaveToLayerFile_management(tin), but i get the same error.
With rasters and shapefiles i just give in input the full path of the file, but about the tin?
Thank you!
IanMurray
Honored Contributor
