Installing a dlpk file using arcgis.learn
8533
8
11-21-2021 05:54 AM
mehdihamdoune
Hello everybody,
I'm working on a deep learning project and I needed to use a trained model. But when i want to install it, an error shows up that i don't understand.
RunTimeError : model should be created from a portal item or a portal url.
Can anyone explain me the error and tell me how to fix it ?
Thanks for your attention and for your help.
MehdiPira1
Hi @mehdihamdoune ,
It should work if you first add the dlpk file to Portal/AGOL from Content > Add Item then get it in your script via item id as follows:
detect_objects_model_package = gis.content.get(item_id)
detect_objects_model = Model(detect_objects_model_package)
detect_objects_model.install(gis=gis)
I hope that helps.
mehdihamdoune
MehdiPira1
Hi @mehdihamdoune ,
I hope that helps.
Mehdi99
Thank you for the response, it works.
MehdiPira1
Glad to hear that @Mehdi99 .
Mehdi99
DanPatterson
MVP Esteemed Contributor
is it one of these tools?
Classify Pixels Using Deep Learning (Raster Analysis)—ArcGIS Pro | Documentation
The input model of this tool will only take a deep learning package (.dlpk) item from the portal.
... sort of retired...
mehdihamdoune
It isn't this tool, but similar to it. We're classifying 3D pointclouds.
DanPatterson
check the tool you are using, they have the restrictions listed in the tool's help topic
