How to update/reset users.categories
3256
7
02-07-2024 08:27 AM
AndreasEugster
Is there a way to reset the gis.users.categories? Or update / remove specific entries in the memberCategorySchema?
gis.users.categories = None
will delet all the user-categories, but reloading a memberCategorySchema will fail afterwards.
gis.users.categories = {'memberCategorySchema': [
{'title': 'Categories','categories': [{'title': 'bla','categories': [{'title': 'bli','categories': [{'title': 'blu'}]}]}]}]}
self._gis.users.categories[0]["categories"]
IndexError: list index out of range
Clubdebambos
MVP Regular Contributor
Hi @AndreasEugster
What error are you getting? It it this...
ValueError: A list or tuple must be given to set the categories.
I get this error if the categories is already set to None. Worked around it with the below.
from arcgis.gis import GIS
agol = GIS("home")
## only update to None if it is not already None
if agol.users.categories != None:
    agol.users.categories = None
user_schema = {
            'categories': [
                    'title': 'bla',
                    'categories': [
                            'title': 'bli',
                            'categories': [
                                    'title': 'blu'
agol.users.categories = user_schema
print(agol.users.categories)
~ learn.finaldraftmapping.com
David_McRitchie
Hey Andreas have you tried using gis.content.categories.delete()?
Based on the documentation you may need to fully remove the the category schema, remake and reassign this.
Hope that helps,
David
Esri UK -Technical Support Analyst
AndreasEugster
Thanks for the reply.
Your answer refers to content-categories... I'm talking about user-categories and the "memberCategorySchema". There is no gis.users.categories.delete()...
Clubdebambos
Hi @AndreasEugster
I am using arcgis api version 2.2.0.1 and I have no issue with the following.
Create a user category schema
agol = GIS("home")
user_schema = {
    "memberCategorySchema": [
            "title": "Office Location",
            "categories": [
                    "title": "USA",
                    "categories": [
                            "title": "Maine"
                            "title": "California",
                            "categories": [
                                    "title": "Redlands"
                                    "title": "San Diego"
                    "title": "Europe",
                    "categories": [
                            "title": "Zurich"
                            "title": "Edinburgh"
        "title": "Department",
        "categories": [
                "title": "Sales"
                "title": "Consulting"
Print to test... I wont add results put it prints fine
agol = GIS("home")
Delete the schema
agol = GIS("home")
Re-print, it returns None.
Re-assign a new schema.
agol = GIS("home")
user_schema = {
            'categories': [
                    'title': 'bla',
                    'categories': [
                            'title': 'bli',
                            'categories': [
                                    'title': 'blu'
Printing new schema works just fine.
agol = GIS("home")
print(agol.users.categories[0]["categories"])
##prints
[{'title': 'bla', 'categories': [{'title': 'bli', 'categories': [{'title': 'blu'}]}]}]
AndreasEugster
Hi @Clubdebambos
Strange... Can you confirm that the snippet works if you re-assign the schema directly after setting it None without "reconnecting" to GIS("home")?
agol = GIS("home")
user_schema = {
            'categories': [
                    'title': 'bla',
                    'categories': [
                            'title': 'bli',
                            'categories': [
                                    'title': 'blu'
## results in error?!
## however with "reconnecting before re-assigning" it works:
# agol = GIS("home")
# agol.users.categories = user_schema
why the "re-connection"?
Clubdebambos
Hi @AndreasEugster
agol = GIS("home")
user_schema = {
            'categories': [
                    'title': 'bla',
                    'categories': [
                            'title': 'bli',
                            'categories': [
                                    'title': 'blu'
AndreasEugster
Hi @Clubdebambos
As soon as the users.categories are None I can not reasign the schema anymore... unless I'm reconnecting to agol once more (agol = GIS("home")) before asigning the schema. Doing it in one run without reconnecting results in the error: ...in categories
for category in self._gis.users.categories[0]["categories"]:
I'll try with the latest arcgis api version 2.2.x (rigthnow using 2.1.x) and also outside our internal-network. I'll provide an update later 🙂
AndreasEugster
Seems to work with 2.2.0.x 👍
Did not check if internal-network or 2.1.x was the issue tho.
