How to Turn On Labels and Enable Offline for a Web Map?
903
07-11-2025 12:43 PM
Labels (3)
SH_DH
With the new Python API update I'm having trouble seeing how to turn on labels for a layer. I'm not seeing a parameter in layer properties. How can I turn these on?
Also, the recent update requires you to manually turn on Offline Enabled for a map. Is there a parameter for this?
Clubdebambos
MVP Regular Contributor
Hi @SH_DH,
To turn on/off labels you can use the following...
from arcgis.gis import GIS
from arcgis.map import Map
## Access AGOL
agol = GIS("home")
## get the WebMap as an Item Object
wm_item = agol.content.get("WM_ITEM_ID")
## create the Map object from the Item Object
webmap = Map(wm_item)
## the dictionary for the options parameter in update_layer()
options_dict = {
    "showLabels" : True # or False
## Map object > MapContent > update_layer()
webmap.content.update_layer(
    index = 0, # index of the layer in the WebMap
    options = options_dict
## commit the change
webmap.update()
This assumes that you have label classes already set in the WebMap that will be used once the labels are turned on.
All the best,
Glen
~ learn.finaldraftmapping.com
Clubdebambos
Hi @SH_DH,
## Access AGOL
agol = GIS("home")
options_dict = {
webmap.update()
All the best,
Glen
SH_DH
Thanks Glen, I just finally returned to updating my code and your snippet worked.
